P28 ECU to OBD2B
Old Nov 29, 2011 | 11:39 AM
00IntegraR's Avatar
Default P28 ECU to OBD2B
2000 Acura Integra Type R
Is it any different then any other OBD2B car? I am trying to figure out why my car is running stupid rich this winter. I know my wideband is supposed to go into D10 ELD on the OBD1 ECU. So last night I decided to double check it. I pull up AllDataPro and look at my ECU wiring. It says Pin A30 is a Grn/Red wire going to the ELD. I look at the way my car is wired and it is going into A27 Grn/Red. EUREKA! Quick fix it was wired in wrong.....Not so lucky. Pin A30 is a Blu/Red wire?!?! WTF?!?!?! So then I open the OBD1 ECU (P28) and the board is clearly marked A, B, D and outer edge pin numbers. I ohm Pin D10 to C8 on the OBD2B engine harness. Check my wiring diagram and it says CKFP..... The original car has a P73-A04 ECU. Does anyone have any ideas or ran into anything like this before? I hooked the A30 Blu/Red wire up and it read 4.93v all the time. No change on or off throttle. So I put everything back to how it was for now. At least the A/F was changing on A27. I doubt it is right but at least it appears to be a sine wave.
Found a picture showing the same thing as my car. The bottom left is A32 (empty hole), A31 is Grn/xxx and A30 is Blu/Red.
Old Nov 29, 2011 | 05:28 PM
Blown90hatcH's Avatar
Default Re: P28 ECU to OBD2B
Negative. Bottom left empty hole is A25. You read it from the wire side inward into the ecu....
A plug
1 2 3......10 11
12 13 14.......23 24
25 26 27......31 32
myefhasaname
Feb 27, 2013 08:45 PM
00IntegraR
Nov 29, 2011 08:54 AM
liquidrider
Jul 29, 2009 01:55 PM
drift2004
Feb 27, 2008 01:53 PM
