RSX type s PO341
P0118 Engine Coolant Temperature Circuit High Input
P1362 which is the TDC code, or camshaft position sensor
What have you tried if anything? I would look at your cam sensors. I have seen some gone bad before. . .
po1632 n po341 is gone but its just showing
P0118 Engine Coolant Temperature Circuit High Input where can i find that at?
well technically speaking the Crank Position sensor works hand in hand with the cam sensors for the engine to accurately read timing. So it could be a crank sensor... sucks having a guessing game unless you have a REALLY expensive scanner that tells you exactly what it is.
