for fuk sakes!! not again da8 b16a
Old Nov 28, 2011 | 10:20 PM
standy xsi's Avatar
Default for *** sakes!! not again da8 b16a
here we go again! 2nd motor put in an sounds like its got a nasty rattle.. yes im young and learning only just started working on cars in march..
im trying to upload a video now that i will post on here.
my gess is throw out bearing stuck on?
pluss it also heated up reeal fast!! im new to this and really need help!
ask questions if u need to, im still down about motor so almost speachless
Old Nov 28, 2011 | 10:23 PM
standy xsi's Avatar
Default Re: for *** sakes!! not again da8 b16a
i also forgot to say my clutch was qiut stiff before i starteed it up. and then it got stuck in gear? had to turn it off.. ive been at it all day.. goin to take gearbox off tomorw and start it with just a barrel housing to "knock" (ha) some problems off.
any advice would be great thanks
Old Nov 28, 2011 | 10:25 PM
jaymiahson's Avatar
clutch? im pretty new to this too but if u swapped the motor and this one overheats n all that u might have a burnt out clutch dude and did it heat up just when u started it up or did u drive it around?
Old Nov 28, 2011 | 10:40 PM
standy xsi's Avatar
yea like had a burnt smell in the shed that was a little like clutch. um ive started it three times so far. first time turned it off nearly str8 away. secound time had it running for 5 - 10 mins. both radiator hoses got wel.. extremly hot!.. there was also black smoke pilling out off the mufler? and reason why im looking at clutch an gearbox etc is i drove it up out of the shed bowt 5 metres then it got stuck in gear, so turned it off put in reverse then backed into the shed. once in shed got her in nuetral then tryed putn it in gears and it wouldnt go. makn crunching noises like i didnt have the clutch on
Old Nov 29, 2011 | 07:05 PM
standy xsi's Avatar
turns out it was the crank pully!! loose as f**k!. its now got me scratchen my head bowt wat else the previos owner has done? he took the effort to get it machined and acid dipped, head and block.
Please give me your thoughts!
worth dismantling and then tourqing everything back down to spec?
he put b18c valves in and b16a2 cams in a pr3-4 head. surely he wouldnt half *** it?
advice please im young dumb and full of ***
Old Nov 29, 2011 | 07:24 PM
mouab18c1's Avatar
Take it to a mechanic that knows what they're doing or keep ******* with it until it blows. You choose!
stdefhatch
23
Jul 22, 2007 12:04 PM
machine4321
Aug 2, 2003 06:47 PM
VR6T
Apr 17, 2003 01:41 AM
88turdbucket
Feb 3, 2003 01:51 PM
