NC FS: 1993 H2B civic coupe *tucked*
Throwing around the idea of selling my baby. I dont need the money so dont act like i do.
No bullshit offers. I want $6200
1993 EJ1 coupe
119,500 miles
clean title
shittty paint
no accidents whatsoever
no major dents or rust just typical wear
Engine (less than 1500 miles, just finished break in period)
broke in properly. 240 psi dead even on all 4 cyl.
93 H22A1 block
ACL bearings
stock pistons and rods
crank micropolished and balanced to 10k
Hastings rings
hot tanked
99 H22A4 head
milled .020 by RLZ (yields 10.6:1 compression ratio)
Ferrea valve seals
stock valvetrain and cams
mild port and polish
hot tanked
stock intake manifold with IABs deleted
EGR delete
NGK blue plug wires
MAP sensor relocated
brand new DSM 450cc injectors
2.5 in mandrel bent exhaust no cat or muffler (sounds like my GSXR above 7k)
Kaizen Speed oil pump with balance shaft delete
full balance shaft kit delete installed (oil galley plugged, dowels pressed in girdle, etc)
Logic Motorsports tri-y race header (won the Jaywest H2B header shootout)
custom single row crank pulley that i machined
engine assembled by me and jason k.
Evolution/Bisimoto H2B kit (ZERO ISSUES AT ALL)
S4C B16 transmission
Competition Clutch Stage 4 ceramic/kevlar 6 puck sprung
new axle seals
new CV axles
brand new:
ignition coil, rotor, cap
timing belt
water pump
oil pump
starter
front main seal
rear main seal
valve cover gasket
head gasket
radiator hoses
clutch slave cylinder
cylinder head dowels
thermostat
VTEC solenoid and gasket
every gasket or seal in the entire engine bay has been replaced
almost every bolt in the bay was replaced (oem honda) because im OCD and if its dirty i dont like it.
i did this build with no prior parts, so EVERYTHING was purchased new
if it was a moving part that had age and could fail, i replaced it. i <3 reliability.
Custom tucked harness that i spent a whole fuking week making. heat shrinked and sleeved in blue flex braid sleeving. looks sick with the tastefully color matched blue/silver/gray bay theme.
Engine bay professionally painted 06 TSX charcoal gray
Downstar Inc dress up bolt kit for fenders/headlights/clutch master/ground/radiator stay
semi tucked fuel and brake lines.
Bride driver seat and rail, stock passenger seat
205/55/14 Nitto drag radials
The boring:
stock suspension/brakes/wheels
no AC/PS/heat or blower motor
no CD player
Bottom line:
Everything in this bay has been meticulously disassembled or removed and polished/restored/repainted/beautified. I spent months making sure this bay was above and beyond the norm. The proof is in the pudding. I used the best parts and built this engine with the best attention to detail you can find, and it shows. It made over 200 whp and 160 tq when Howard tuned it at RLZ. It runs flawlessly. No issues. Makes power over 8k and will burn the tires off to 60 mph. It seriously SPINS shifting into 4TH GEAR. ALL MOTOR, STOCK ENGINE!!!!!
Make me an offer
1993 EJ1 coupe
119,500 miles
clean title
shittty paint
93 H22A1 block
ACL bearings
Hastings rings
hot tanked
99 H22A4 head
Ferrea valve seals
hot tanked
EGR delete
NGK blue plug wires
new axle seals
new CV axles
brand new:
timing belt
water pump
oil pump
starter
front main seal
rear main seal
valve cover gasket
head gasket
radiator hoses
thermostat
The boring:
no CD player
Bottom line:
Make me an offer
by the way, i will part out the drivetrain for $4300 FIRM. that includes axles, ecu, everything.
Hi im an new h2b builder and i was wondering how did the 450cc injector works for you? i was told rc440 was better but if i cant found one I might get the 450cc set instead.
with a 10cc difference there isnt a real performance advantage with either. honestly rc has somewhat of a rep with the engine builders and tuners that ive talked to (including brad and howard at rlz), to have out of the box injector failures. DSMs are factory injectors from mitsubishi. you really cant get much more reliable than that. buy brand new ones from phearable.net and dont worry. 450s support around 240-250 hp at the crank for me with a relatively low duty cycle and getting 20-25 mpg on a relatively rich tune. i like them.
2literCR-X
Aug 4, 2009 07:05 AM
dseriesdrag
Jul 8, 2008 03:47 AM
