Ek4 F22A1 swap.. Cylinder 1 getting spark, fuel, but not working properly
Old Nov 28, 2011 | 01:30 PM
victor.ek4's Avatar
Default Ek4 F22A1 swap.. Cylinder 1 getting spark, fuel, but not working properly
Hi there HT...
I have a 1997 EK4 with a F22A1 swap on a B trans soon to be boosted, but I am encountering some problems with it...
Cylinder one has spark, fuel, but it burns MUCH colder than the other ones (checking the echaust with a thermometer), and if I remove the spark plug and/or the injector plug, it makes very little difference, but still, makes more difference when I re-plug the injector then when I remove it..
The engine is a fresh rebuild, with forged rods and stock pistons, head was rebuilt also...
what I noticed is that the valve lash that I setted to 0.30mm is now 0.45 HOT, so I assume I could have a bent valve... BUT, on stock cams, pistons, valvetrain and with the timing set acordingly, that should not have happened....
Ideas?
I´ll post pictures of the swap soon... THanks in advance
Old Nov 28, 2011 | 03:40 PM
victor.ek4's Avatar
Default Re: Ek4 F22A1 swap.. Cylinder 1 getting spark, fuel, but not working properly
pulled the head... fried sleeve on cyl 1.. probably no clearance... all 3 others scraped
Old Nov 28, 2011 | 03:46 PM
holmesnmanny's Avatar
That sucks dude.
TravisBiggie
Sep 29, 2013 06:33 PM
slowwcivic
May 25, 2011 06:18 AM
jvillagran2000
15
Dec 2, 2008 02:03 PM
toastytheog
Jul 16, 2007 09:26 AM
