wobbly/loose steering, bad steering feedback
Old Nov 28, 2011 | 02:25 AM
anzai's Avatar
Default wobbly/loose steering, bad steering feedback
hey guys since about 4 weeks ago i've noticed that the steering on my itr is very woobly/loose, there is heaps of play and i can't seem to be able turn into a corner as sharp as it used to be.
i spoke to a few people and mechanics to get the following checked: tie rods ends, ball joint, cv joint and other suspension components. everything is tight and normal except that my bottom coilover perch is loose (the bit you undo to adjust height), not sure how. we tightened that up but still to no avail.
my rear trailing arm bushings is on its way out, im in the process on getting new oem bushings but i doubt this is the cause of my problem.. can anyone clarify?
this all started happening after a major service to replace timing belt and the tensioner pulley, as well as replacing my old pads which was 3mm thick with flaking off edges. a few days after i noticed my steering hub cover was not screwed on properly so i tightened that up, could something on the steering column shat itself?
anyway the last thing i haven't done is alignment, but i doubt it'll do anything since i got it done last in july..
thanks in advance
Old Nov 29, 2011 | 01:44 AM
steadysupreme's Avatar
Default Re: wobbly/loose steering, bad steering feedback
how about tire pressure and this, https://honda-tech.com/forums/acura-integra-type-r-8/streeting-rack-adjustment-fix-any-loose-steering-569090/
Old Nov 29, 2011 | 03:45 PM
DCMikey's Avatar
could be as easy as tightening the axle bolts.
Assassinxiv
Suspension & Brakes
May 13, 2013 02:45 PM
buzkilr
May 26, 2011 12:21 PM
Annihilator
Feb 9, 2011 12:03 AM
Ventolin
May 14, 2008 11:45 AM
dpo95si
Apr 24, 2002 03:19 PM
