VAFC --> will it lose all memory?
Old Oct 7, 2002 | 11:39 AM
EleanoR's Avatar
Default VAFC --> will it lose all memory?
Ok i am pretty sure the answer to the question is no but i want a definite answer. I am going to be replacing my steering wheel in the new few weeks. I have to shut off the power to the car via disconnecting the negative battery terminal from the battery. This won't mess up the settings on the VAFC correct?
Mike
Old Oct 7, 2002 | 11:42 AM
Nate B's Avatar
Default Re: VAFC --> will it lose all memory? (EleanoR)
No, you can even disconnect the V-AFC from it's harness when the car is off and it wont erase its memory. As long as the car is off you'll be fine
Old Oct 7, 2002 | 11:43 AM
EleanoR's Avatar
Default Re: VAFC --> will it lose all memory? (TypeR#1111)
thank you
Old Oct 7, 2002 | 11:53 AM
B2FiNiTY's Avatar
What happens if you disconnect the vafc from the plug and try to start and drive the car?
Old Oct 7, 2002 | 11:57 AM
Nate B's Avatar
Default Re: VAFC --> will it lose all memory? (ExOdy)
The car would run all fugged up. I accidently did it and my Idle was at like 100rpms and everything was acting shitty. Don't do it.
Old Oct 7, 2002 | 11:58 AM
B2FiNiTY's Avatar
Can you still drive it? Thinking about using it as a theft deterrant.
Old Oct 7, 2002 | 12:00 PM
Nate B's Avatar
Yeah, you can still drive it. But a thieve would **** up your car bad if he drove like that.
Old Oct 7, 2002 | 12:01 PM
B2FiNiTY's Avatar
hmm...better not then.
s2kc's
Jul 14, 2005 07:18 AM
ReeH!
Sep 29, 2003 11:23 AM
Sukebei Oni
Mar 23, 2003 10:04 AM
SpeedRacer00-667
Mar 1, 2003 07:16 PM
