Quick & Dirty Racing: Swaps, Part Outs, Aftermarket
Old Nov 27, 2011 | 06:27 PM
Atmosfear's Avatar
Default Quick & Dirty Racing: Swaps, Part Outs, Aftermarket
Quick & Dirty Racing is a local Honda Time Attack and Rally team. We are dedicated enthusiasts whose primary goal is to promote local track and rally events and to educate people who are interested in participating on how to get started.
As a means of funding our expensive hobby, we created a side business offering both new and used parts to fellow Honda enthusiasts.
All swaps will come with a Bill of Sale printed with company letterhead and will include the VIN # of the donor vehicle. We only purchase from legitimate sources so that we in turn only offer legitimate parts.
Since we do not operate a traditional storefront/shop, we have a close relationship with the top Honda/Acura shop in the Northwest, Speedfactory Tuning & Race Fabrication. The SF crew is the friendliest, most competent group of individuals in the region whom are willing to assist with any labor and additional needs you may have that you are not comfortable with performing yourself.
To make the most efficient use of both your time and ours, all parts will be sold either locally in the Lacey/Olympia area, or at the Speedfactory location. We understand that not everyone has the ability to transport large/heavy items. For this reason, we also offer a delivery service for larger items such as engine swaps, however; we will only deliver to your home address or a location that will be performing the installation for you. All deliveries are made in a large enclosed cargo van so that your parts are not exposed to the elements (NOTE: depending on distance, you may be asked to pay a fuel surcharge). This policy is in place due to numerous instances of “no shows” in the past.
The thread will be updated often so be sure to check back frequently, or subscribe!
We do our best to have pictures available, however most parts and vehicles are often stored offsite so please be patient if requesting pics.
Our website is presently under development. For the time being, I am most easily reached via PM or email at quickndirtyracing@hotmail.com
Old Nov 27, 2011 | 06:28 PM
Atmosfear's Avatar
Default Re: Quick & Dirty Racing: Swaps, Part Outs, Aftermarket
OBD2 B18C1 complete swap w/ Bill of Sale & VIN #: SOLD
Atmosfear's Avatar
OBD1 H22A1 complete swap w/ Bill of Sale & VIN #, $1,600.00: Removed from a 1993 Prelude w/ unknown miles. No smoke, runs strong.
Compression Test Results (engine warm): 245/240/245/245
Includes engine, harness, non-lsd transmission, intermediate shaft (no axles), mounts, power steering pump w/ cut line (the portion needed to retain ps when swapped into non-prelude/accord), fuel line, stock OBD1 P13 ecu, shifter cable assembly, all bolts/hardware. Aside from the missing axles, this is the most complete swap you will find.
*Aftermarket Mounts & conversion kits (Innovative/Hasport), new axles or swap axles, aftermarket LSD's (Quaife/Wavetrac/Cusco/etc.), or other performance parts available for additional cost.
Atmosfear's Avatar
Available for part-out: 1999 Acura Integra GSR Sedan (DB8). Clover Green Pearl (G-95P) exterior, Tan leather interior.
132,526 miles. Rear impact, trunk and rear bumper support area are damaged. All other parts in very good condition.
-Front end (hood, fenders, bumper, headlights, turn signal lenses) SOLD
-Rear seats (upper and lower), tan leather. SOLD
-Radiator & fan SOLD
-Gauge cluster SOLD
Below is a small list accompanied by pictures of just a few of the items that are available. Please PM or email if you need something that is not listed below. More pics will be available as parts are removed. Swap, brake and suspension components, interior, etc. all still available.
Front bumper beam
$20.00
-Rear disc swap, dimpled/slotted rotors w/ like new pads. Complete with everything needed to perform a rear disc conversion including e-brake cables & mounting brackets and brake lines. $140.00
*Aftermarket or OE replacement rotors, pads, SS braided lines, and suspension bushings, and suspension arms available for additional cost.
-Front brake/knuckle assembly, dimpled/slotted rotors w/ like new pads. $80.00
-All interior panels, dash, headliner, center console, etc. $ price varies by part
-Doors, front and rear. $ price varies by part
-Windows (tinted), front and rear. $ price varies by part
-Front windshield, $60.00
-1" brake master cylinder w/ booster, $60.00
-Clutch master cylinder $20.00
-Front subframe brace w/ hardware, $20.00
-Front swaybar with all mounting hardware, $60.00
-Rear swaybar with all mounting hardware, $30.00
-Electrical related items (wiring, relays, switches, fuse box, abs module, etc.) $ price varies by part
-Cat back exhaust, flanged where it meets the cat, otherwise it is one solid welded piece w/ OBX-R muffler. $30.00
-Power sunroof assembly. Will include necessary hardware, wiring pigtails, switch, etc. $60.00
-OBX-R rear lower tie bar. $10.00
-OEM shocks, front and rear (no leaks) with Eibach springs, Part # available. $60.00
Old Nov 27, 2011 | 06:29 PM
Atmosfear's Avatar
Available for Part-Out: 1995 Integra GSR Coupe (DC2), Black exterior, black leather interior.
125,036 miles. Major body damage throughout, all useable body panels have been sold.
-Complete swap SOLD
-Gauge cluster SOLD
-Interior plastic panels SOLD
-Black GSR leather seats: Front & Rear SOLD
-Rear disc conversion SOLD
Cat-back exhaust w/ stock muffler: $40.00 *Welded as one piece, flanged where it meets the cat.
Pass. side door panel: $20.00
Rear cargo cover: $40.00
Front brake conversion: $60.00
Power Sunroof Assembly, includes switch, wiring pigtails, and hardware: $60.00
-Cat-back exhaust w/ stock muffler: $60.00
-Pass. side door panel: $20.00
-Rear cargo cover: $40.00
-Front brake conversion: $60.00
-Passenger side window, $20.00
-Passenger side window regulator (power), $20.00
-H&R Springs, front and rear, Part # available. $30.00
Old Nov 27, 2011 | 08:07 PM
Atmosfear's Avatar
Available for part-out: 1993 Honda Prelude Vtec, unknown mileage (cluster was destroyed).
Major body damage throughout, all useable body panels and interior panels have been sold.
Below is a small list (pictures pending) of just a few of the items that are available. Please PM or email if you need something that is not listed below. Pics will be available as parts are removed.
-Complete swap (see above).
-Stock cat-back exhaust $60.00
-Front and Rear brake and suspension components.
-Several Misc. parts still available.
Old Nov 27, 2011 | 08:37 PM
Atmosfear's Avatar
3" AEM hybrid cold air intake designed for B-series swaps in EG chassis. This was only used for a few SCCA Time Trials events and was then removed. Aside from the minor scratches and one dent pictured, the tubing and filter is like new. The dent and scratches are on the bottom side of the piping and cannot be seen when the intake is installed. All hardware and manufacturers literature included.
$140.00
FAL dual fan setup for 94-01 (DC) Integra radiators. Includes hardware and installation literature. A bit of the raised plastic edge was shaved to install on a custom radiator, the lower corner was also trimmed to clear the lower radiator hose. Everything functions perfectly fine. This can all be seen clearly in the picture.
$140.00
SARD (JDM) coolant breather tank. Brand new in original packaging.
$80.00
SARD coolant hose adapter. Brand new. This is used to install a coolant temp. sensor. Includes hardware.
$30.00
B-series header, unknown brand. Skid plate welded to lower portion. This was removed from a parts car, the collector flange was cut off and welded (poorly) to the exhaust section. This will need to be fixed or installed in the same fashion.
$60.00
Focuz brand exhaust resonator
$20.00
B16A2 oil pan, windage tray, pickup.
$40.00
B16A2 Intake Manifold (bare). DOES NOT include the injectors, fuel rail.
$20.00
B-series Magnecor plug wires.
$40.00
B-series aftermarket plug wires, unsure of brand.
$20.00
Del Sol B-series shift linkage, shifter not included.
$80.00
Misc. intakes, several available, not all are pictured. Two available with Blox filters and velocity stacks, $50.00 each. All others $20 each.
B-series Intermediate shafts.
$40 each.
Used B-series axles.
$50 per set.
D-series vtec valve cover. Needs to be cleaned.
$20.00
Loads of wiring and connectors. OBD1 & 2 mostly. Engine, bay, interior, etc from misc. Hondas/Acuras.
Tire chains,Brand new in original packaging. If I remember correctly these fit 14-16" wheels.
$40.00
Old Nov 27, 2011 | 09:08 PM
Atmosfear's Avatar
"Replica" powered mirrors. Painted a gunmetal-ish color, no plugs with wiring.
$20.00
Old Nov 27, 2011 | 09:10 PM
Atmosfear's Avatar
EG hatch tailgate, Milano Red. No significant damage but far from perfect.
$20.00
Old Nov 27, 2011 | 09:35 PM
Atmosfear's Avatar
Avid Racing Pro-Series Traction Bar for EG Civic. The bar was installed on my car and has some scratches and scrapes. The radius rods and aurora rod ends are brand new and were never installed.
$160.00
Sparco Circuit fixed back racing seat in Black. Has typical scratches and scrapes on the back of the shell, and on the right side which is mostly obstructed by the trans tunnel and center console.
Comes with side mount brackets and Red Bull sticker! (I will remove the sticker if you want)
I can also provide a brand new Sparco seat base and slider to fit any car that Sparco makes a base for, this of course will cost extra and will also take a few days to arrive.
$500.00
"JDM" Black Racing 14x6 wheels. Gunmetal grey color, they look a lot like older style Watanabes. 2 tires are useable, 2 tires have substantial inside wear. Bought from Steve @ H-Motors less than 2 months ago. I sold the car I planned to put them on. One wheel has very minor curb rash on a small section (pictured below). The others have some areas on the edge of the wheel where the coating has been scraped off from mounting/dismounting tires (also pictured below).
$350.00
JL Audio Subwoofer box designed to house a JL 12W7. The box was removed from a wrecked car and was banged around a little bit which damaged the edges as seen below. It also had a nice shiny plate that screwed onto the front of the box with the JL W7 logo however the plate was also damaged and is not useable. Other then the edges the box is in good shape, no other damage. Just needs a good vacuum and cleaning.
$20.00
Tanabe Sustec Pro SO-C Type II Coilovers with OEM tophats meaning that they are ready to bolt up, EG/DC fitment. No leaks, one small dent on one of the lower shock bodies. Perfectly functional.
$450.00
*pic pending*
Old Nov 28, 2011 | 11:20 AM
project93hatch's Avatar
SUSBCRIBED! ALWAY WILLING TO SUPPORT LOCALS.
Old Nov 29, 2011 | 05:58 AM
Atmosfear's Avatar
^^^^Thanks!
Morning Bump. Sparco Circuit race seat added to sale list, pic pending.
Old Nov 30, 2011 | 06:15 AM
Atmosfear's Avatar
Skunk2 Pro Series Plus adjustable front upper control arms: SOLD
Old Nov 30, 2011 | 11:35 AM
turnsignalandy's Avatar
do you have a set of 96-00 civic seat rails?
Old Nov 30, 2011 | 07:59 PM
Atmosfear's Avatar
Nope, sorry. Ive got just about everything but EK rails.
Old Nov 30, 2011 | 09:19 PM
reaction360's Avatar
Man, this whole time, I had no idea this screen name was you! I'll hit you up tomorrow for the ps bracket and hose.
Old Dec 1, 2011 | 08:20 AM
Atmosfear's Avatar
^^LOL, hello stranger!
Let me know when you want to stop by.
Old Dec 3, 2011 | 10:43 AM
Atmosfear's Avatar
Bump, more parts and pics coming later today.
Old Dec 3, 2011 | 05:47 PM
KINGVEM^^ED6's Avatar
want that sohc valve cover willl hit u up when im in the area
Old Dec 3, 2011 | 07:55 PM
Royal_C!ty's Avatar
bump for you guys!
Old Dec 3, 2011 | 08:04 PM
92teginsc's Avatar
nice stuff. no ef stuff tho
Old Dec 5, 2011 | 09:31 AM
function83's Avatar
bump for that 99 gsr swap. The orange paint on the block number means its been replaced with a brand oem short block, probably no vin tag. which means less mileage than stated on the cluster.
Old Dec 5, 2011 | 10:27 AM
Atmosfear's Avatar
Sounds good, I will probably still have it.
Originally Posted by Royal_C!ty
bump for you guys!
Thank you sir!
Thanks, and sorry. Most of the EF's I have come across are beat to hell and there is no money in them. I am looking at doing something in the future similar to a group buy where I get some lists going of people who are interested in several parts off of a particular model/chassis.
If I get enough people interested in enough of the various parts to make it worthwile, I will pick one up for part out.
Thanks for the info, I had no idea but was curious. I actually believe it was a complete longblock. After reading your post I went out and looked at it more closely and the code on the head indicates 2001. If you look closely at the pics you can see that you are right, there is no VIN tag. However, everything is completely legitimate and I will provide a notarized Bill of Sale which will include the VIN # of the car it was removed from in accordance with WA state law.
Old Dec 5, 2011 | 06:18 PM
cirix's Avatar
Great seller got my parts today. Bump for the NW.
Old Dec 5, 2011 | 09:40 PM
Atmosfear's Avatar
Thanks! Let me know if there is anything else you need.
