Front End Vibration
Old Oct 7, 2002 | 11:35 AM
norm's Avatar
Default Front End Vibration
I have a 91 EX-R Wagon with an automatic transmission. I have a vibration which occurs during normal driving and braking. I have balanced the rims and tires, aligned the front end, replaced struts and springs, replaced brake rotors and pads (calipers are free and clean), replaced drive shafts and had the bearings , ball joints and tie rods checked. I am at a loss as to where the vibration is originating. Does anyone have any suggestions or could I have a bad C/V joint or axle?
Norm
Old Oct 7, 2002 | 12:10 PM
Ideal's Avatar
Default Re: Front End Vibration (norm)
Sounds like a bad motor mount to me, probaly rear, its usually the rear, naturally the more expensive.
-Jon
Old Oct 7, 2002 | 02:40 PM
carolinaACCORD's Avatar
Default Re: Front End Vibration (Ideal)
-Jon
since it is automatic, it probably has the controlled rear mount.
(at least i think the 4th gen has it, i know the 5th does)
look and see if it does, it will have a couple wires going to it.
Claytd
Aug 21, 2013 11:38 AM
MJ 95 del sol
10
Apr 8, 2013 02:06 PM
jasonacura91
16
Apr 12, 2009 04:21 PM
JDM_SOHC
28
Nov 17, 2006 10:42 AM
force-fed
Nov 5, 2005 07:20 PM
