Please identify swap harness thing!
What's up H-t i just recently bought a crx with a b16 and found some kind of swap harness thingy, at least that's what i think it is, the wires have tape with ecu pinouts that say a1, a5 and b10, b12 but the b10 and b12 wires are plugged in to the C plug, can anyone identify what this is used for, the car has alot of wiring problems and im thinking that maybe a reason, ohh and the engine is OBD2, here are some pictures..
Looks like an obd0 ecu. Someone tried to run the newer engine with an older ecu without a proper harness. What ecu are you running?
Are you positive you have an si? I ask this because those wires look like the ones that would need to be ran in order to do a DPFI to mpfi conversion.
Your car should already be set up and those wires should not need to be ran. I want to go on a limb and say you have a dx model crx.
I could be mistaken but the 88 si's come with the sunroof right??, and i just ran the VIN and it said that it was a crx 1.6, the guy before redrilled seat holes through the chassis, It wouldn't be a surprise to me if he couldn't get his car running and tried everything possible to try and get it running, he cut wires left and right also and half *** put them back together, but i think i might try to repair the interior harness as best as i can, and start off with a new engine harness cause i has plugs missing everywhere
i see your in cali, what part are you in?
also double check n make sure you have the following plugs on your shock tower:
Driver side - 6 wire rectangle plug
Passenger Side - 14 wire round plug, rectangle 6 wire plug and rectangle 8 wire plug
yes 88 si's should also have a sun roof. if you need a new engine harness lmk, i can build you a brand new one. check out my FB link below.
feel free to txt me if you need more help
916-541-5266
916-541-5266
I live close to LA
on the driver side there is a 6 wire plug for the resistor box right
and on the driver side i dont see the 6 wire plug i only have the 14 and 8 wire plug
thanks for the help by the way
I would be interested in a harness how much would a regular one go for??
