2000 gsr has rough idle and won't rev passed 4500 rpm
Old Nov 27, 2011 | 09:52 AM
Slickrick936's Avatar
Icon6 2000 gsr has rough idle and won't rev passed 4500 rpm
I have a 2000 gsr integra that seems to be running extemly rich, it won't rev over 4500 rpm, it Also has a rough idle. I have had the engine machined to 81.5mm with ctr spec pistons. The head has been milled and the block has been decked that is the only thing that has been changed, I have replaced all seals from the valve seals to the oil pan. It has new plugs, new wires, new cap and rotor. It has a test pipe on it. Im still running the stock gsr intake manifold and exhaust manifold and the stock obd2 gsr ecu. I have checked timing and adjusted the valves I have made sure the tps and map sensor are plugged in correctly. It only has one code in it and it's a random missfire. I'm open to any suggestions
Old Nov 27, 2011 | 11:19 AM
standy xsi's Avatar
Default Re: 2000 gsr has rough idle and won't rev passed 4500 rpm
is it blowing smoke?
double check your wires are in fireing order
Old Nov 27, 2011 | 11:31 AM
mouab18c1's Avatar
CTR pistons in your gsr? Did you check ptv clearance? Misfire can be caused by a series of crap. Have you tried a different distributor? Have you also tried a ecu with a somewhat close basemap for the setup?
Old Nov 27, 2011 | 11:46 AM
Icon6 Re: 2000 gsr has rough idle and won't rev passed 4500 rpm
The firing order is correct but it does smoke and it was piston to valve clearance is suffiecint I have not changed ecu's that is a good thought
Old Nov 27, 2011 | 11:48 AM
Sry I messed that up I meant to say the ptv clearance
Was checked
Old Nov 27, 2011 | 12:03 PM
standy xsi's Avatar
did you change intake manifold? i had same problem after changing all my bolt on's.... found out combination of not properly tourqed down intake manifold and wrong fire order was the fault. hope that helps
Old Nov 27, 2011 | 12:45 PM
mouab18c1's Avatar
You shouldn't be running a stock ecu. CTR pistons are way different from GSR pistons. Just looking at it should tell you already.
Old Nov 27, 2011 | 07:05 PM
I am sorry I have a correction the engine is running type r replica pistons not ctr sry
Old Nov 27, 2011 | 07:10 PM
But I'm thinking another ecu and manifold will do the trick
Old Nov 27, 2011 | 09:36 PM
mouab18c1's Avatar
I have ran ITR pistons with a stock ecu before. Car ran fine. I don't think another manifold will do you any good. Try a different ecu
Old Nov 28, 2011 | 01:59 AM
01oemTeggy's Avatar
you and me are having the same problem. keep up to date with my thread on it and maybe we can both figure it out.
https://honda-tech.com/forums/acura-integra-6/rough-idle-problem-then-dies-after-warms-up-3000459/
Old Nov 28, 2011 | 04:00 PM
Poordudes TypeR's Avatar
had the same problem on one of my buddies LSV. replaced the ecu n it worked fine. it actually wouldnt rev past 4000 n it would cut out. but if you slowly got onto the throttle it would rev to about 5 n quits.
if you can find someone with a ecu they would let u borrow for a few n see if thats your problem.
Old Nov 30, 2011 | 07:33 PM
Bump
Old Nov 30, 2011 | 08:22 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
What is the cel?
Old Dec 1, 2011 | 03:59 AM
95tegbuild's Avatar
WAIT WAIT WAIT, coming from the guy who said i was an idiot for running type r cams on a gsr ecu????
Old Dec 4, 2011 | 09:24 AM
1399
Old Dec 10, 2011 | 05:49 AM
I'm gunna order the jumper harness. My brother has a Ecu i can borrow. Bump
Old Dec 13, 2011 | 11:29 PM
01oemTeggy's Avatar
i tried borrowing a friends ecu. a 2000 gsr ecu. the immobilizer wouldn't let me use it?
Old Dec 21, 2011 | 08:34 PM
01oemTeggy's Avatar
my problem ended up being a clogged cat. maybe something to check.
Old Dec 22, 2011 | 08:02 AM
^ well im converting to obd1. Do those ECUs have an immobilizer too? And well i have a test pipe i'll have to check it. Bump
Old Dec 22, 2011 | 08:46 AM
bonesx0x2x4x's Avatar
i have itr pistons in my 98 gsr and it runs fine/ passes inspection on its stock ecu.
u can try picking up another ecu i actually have one that i can sell u 50$ shipped
sounds to me like ur timing might be off but u said u checked it.
kind hard to tell without hearing it so if u can get a vid up that would help
Old Dec 22, 2011 | 10:16 AM
racebum's Avatar
depending on how much was shaved, it usually means you have to degree the cams via adjustable cam gears. check vacuum at idle and if it's something like 15hg and not 22hg you either have a leaky head or cam timing is off.
ignition timing being off is another thing. how does the car idle and when you set timing were you actually able to do so correctly?
it also could be be something as simple as bad plugs / wires.
do a compression test while you're at it, make sure to unplug the distributor before you do
fixing problems like this are a process of ruling things out. if i were doing this i would
1. compression test
2. switch plugs, you can kill a plug by dropping it on concrete so it's not too far fetched
3. try another wire set
4. check cam timing
5. check injectors
somewhere in here you should find your problem
Old Jan 17, 2012 | 03:40 AM
Figured it out thanks everyone for your help..cam timing was off
jlw1964
Jul 8, 2015 04:36 PM
dannykhaos
Oct 14, 2012 09:35 AM
milano2kdc2
Aug 28, 2007 05:49 PM
DocV
Mar 11, 2004 07:23 PM
