Problems with Miller diversion 165
Hey guys I was wondering if anyone has had similiar problems with this machine. It's new, only about 2 months old. The problems I'm having are, when I hit the foot pedal a lot of times nothing happens, there is no arc, however I can hear gas coming out of the end of the nozzle. I then let up off the pedal, wait for the gas to stop and hit the pedal again. Sometimes an arc will start. Other times the same problem will occur 3 or 4 times in a row. Every time you can hear gas but no arc starts. Sometimes I have to turn the machine off and than back on for it to work.
70% of the time it works fine if i'm down there for an hour some days ill wont have a problem at all other days it will work fine except for 3 or 4 times
It happens on mine too, I'm pretty positive it's just poor grounding through the table. Never really bothered me that much, I just lift and try again. If it doesn't go I will move the piece and shift the ground clamp and it will arc then.
Another chiming in to confirm. Mine does this as well. I think it is poor grounding as the others have said. I left the scalling on my table soo. Just touch the tungsten to the work and it'll strike after that.
I am really tempted to get one as I just need a machine to weld things here and there so to speak. How is it with aluminum welding since you cannot adjust the balance or frequency?
Most people don't need those settings.
On my syncro 200, using new aluminum, I've set the balance from one end to the other and can hardly tell a difference, I normally just leave it in the middle.
KillerElfboy
Apr 7, 2008 01:10 AM
