boosting my b18c1
Old Nov 26, 2011 | 07:21 PM
Gsrsi's Avatar
Default boosting my b18c1
i posted this in forced induction but no response so....
i picked up a complete kit from my buddy, it was cheap so i said screw it. i've never boosted a car or had a boosted car. i did some basic research regarding installing and how it would all work but I'm down to this. what would be the difference of running a p28 and a p72 (both chipped). i understand that the 72 lets you open up your secondaries. is it better to run a p28 on a boosted car? (i see a lot of people running the p28) any info is very appreciated. i consider my self a noob when it come to turbos so id appreciate it if any one with an anger problem dosent burn me.
Old Nov 26, 2011 | 07:32 PM
GagnarTheUnruly's Avatar
Default Re: boosting my b18c1
What intake manifold are you using and what tuning solution are you planning on using?
Most people get used p06, p28 or p75 ECUs (because they are common) customized for their build. I/e it will have VTEC added, IAB added if necessary, boost control, and either a socket or an emulator installed.
Old Nov 27, 2011 | 05:04 AM
Ef Hatch 34's Avatar
I've never heard of anyone leaving their stock IM on the GSR and tuning the P72 to also open the butterfly... can it be done if you're trying to boost a stock GSR? wouldn't you gain more power by putting a single stage IM like the skunk2 or type R?
Old Nov 27, 2011 | 07:17 AM
I'm sure the GS-R IM is not the top choice for FI since it doesn't flow very well, but it would work fine until you could get a better IM (like a VictorX).
I don't know much about turbocharging but I speculate that the GS-R IM actually has an around-town advantage, since you can benefit from the bypass until the turbo spools up.
Old Nov 27, 2011 | 07:33 PM
Gsrsi's Avatar
i was pretty sure itr Im's didn't fit b18's but i was just wondering until i obtained a skunk2 or something... but any one have suggestion on injector sizes 57 trim turbo and at max i would only want 10psi.
Old Nov 27, 2011 | 07:58 PM
Gsrsi's Avatar
any opinion on what size tb i should get
Old Nov 27, 2011 | 08:32 PM
doood's Avatar
been there done that
send it to www.maxbore.com
Old Nov 27, 2011 | 08:40 PM
I would guess that 550 would be about right for injectors, depending upon your power goals. But the all motor guys have started using 770 or 1000 ID injectors because the spray is so much better than the old RCs. My uneducated guess is that those would be OK as well.
Best advice is to lurk the FI forums and see what injectors people use with what builds.
Edit: removed bad info (at least the bad info I'm now aware of!)
Old Nov 27, 2011 | 09:25 PM
doood's Avatar
OE itr manifolds wont bolt to a gsr head. you need a skunk2/blox copy. 1000cc injectors will support any amount of power you can make. dont forget the pump and fpr.
Old Nov 27, 2011 | 09:42 PM
DirtyDA9's Avatar
What you could do, is sell me the turbo setup for cheap
Old Nov 27, 2011 | 10:25 PM
sebTeggy's Avatar
Don't just add 1000cc injectors to be safe. That isn't how it works. 2 things control your fuel, injector size, and duration (controlled by ecu, it is tuneable)
Bigger isn't necessarily better.
Also, https://honda-tech.com/forums/forced-induction-16/b18-gsr-intake-manifold-restriction-2882577/
Go down to 01-09-2011, 08:23 AM
OEM MANIFOLD WILL DELIVER! :D
ECU doesnt matter, peopel use p28 because of obd1 compatability. p72 is either obd1/2.
Use either, I'd get a gsr one to be perfectly honest.
Old Nov 27, 2011 | 10:40 PM
doood's Avatar
why not go with the bigger injectors? gives you plenty of room to grow and lower duty cycles
Old Nov 27, 2011 | 11:08 PM
DirtyDA9's Avatar
Exactly what I was going to say^^^ You can never go to big because you can always adjust duty cycle and pulse width.
Old Nov 28, 2011 | 10:43 AM
Gsrsi's Avatar
What's a good price for a tune I don't want to get ripped off.
Old Nov 28, 2011 | 10:59 AM
sebTeggy's Avatar
Ull pay a few hundred. But its not the price I would be worreid about, but the quality of the tune.
Old Nov 28, 2011 | 11:01 AM
Gsrsi's Avatar
For them to tune my ecu does it have to be chipper already
Old Nov 28, 2011 | 11:41 AM
sik96teg's Avatar
as long as its an obd1 ecu w/ vtec u are good. you dont need an after market fpr or fuel pump for 300hp which is around what u will hit at 10 psi on a 57 trim turbo but i would replace the fuel pump just to ensure it doesnt go out on you. If you plan on getting tuned on e85 then i would go with 1000cc injectors if not then jus get some dsm injectors since they are cheap and you can always resale them for the same price if u upgrade them in the future. You will also need to go with atleast a 2.5in exhaust. it would also help if you post what you currently have on your car and everything you got in the kit.
Gsrsi
Nov 26, 2011 10:36 PM
chaokongz
May 12, 2009 02:25 PM
.I.Need.Money.
Aug 4, 2006 12:42 AM
dose
Nov 29, 2002 06:44 AM
