Steering wheel play??
Old Nov 26, 2011 | 05:11 PM
lxdriver's Avatar
Icon2 Steering wheel play??
So today I took my civic to firestone to get an alignment and the tech guy said that there is "play in the steering wheel." Also he said that the car needs rear strut bushings. Can anyone put more information about these two issues please, any help is greatly appreciated. Thanks in advance HT guys.
Old Nov 26, 2011 | 05:20 PM
Jdubbs6101's Avatar
Default Re: Steering wheel play??
Maybe your steering bushings ....cars with p/s....are bad or maybe your tie rod ends inner and outer are worn your rear lower control arm bushings are prolly rotted and torn that and maybe your trailing arm bushings but oh way to be certain is to jack the car up and look at it but that's about all I can guess at your description was rather vague
Old Nov 26, 2011 | 06:31 PM
EJ1_CRIS_909's Avatar
http://www.lmgtfy.com/?q=honda+steering+wheel+play
Old Nov 26, 2011 | 06:38 PM
tegtuner01's Avatar
^^thats AWESOME!!!!!!
Old Nov 26, 2011 | 06:54 PM
hyperblu's Avatar
Most likely inner or outer tierods...
Old Dec 6, 2011 | 10:03 PM
lxdriver's Avatar
So now that I replaced both tie rods (inner n outer), the steering wheel still has some play to it. Is that normal or not? I would say it has about 1" of play without actually moving the wheels.
Old Dec 7, 2011 | 06:10 AM
axis11's Avatar
There's more than a dozen things to cause a steering wheel play. Start with the most obvious. Put the car on a lifter or jack it up and have blocks under the front tires. Reach under the car and shake and pull the steering components to see where the play is coming from. If all seems good, have somebody move the steering wheel slightly back and forth(just enough to have resistance but not to move the tires. Check visually which parts have a play in them. Check parts in the steering arms, rack and pinion assembly,bushings gears, cross joints and plastic bushing in the column. If no P/S , check adjustment bolt near tip of the rack.
KingDakota12
May 22, 2011 06:33 PM
lildragon'07
13
Jun 2, 2010 08:31 AM
buzlink
18
Nov 7, 2006 07:04 AM
jabroni95gsr
Feb 13, 2003 04:12 AM
Toptul_Honda
28
Jan 29, 2003 06:15 PM
