help water leak
Old Nov 26, 2011 | 03:58 PM
honda01civ's Avatar
Default help water leak
hello everyone my sister is having a problem with her 02 accord the passanger side from the front of the seat carpet is wet all the way to the rear seat carpet. i cant seem to find the problem someone also said it was a common problem please help thank you
Old Nov 26, 2011 | 04:09 PM
jdowen2's Avatar
Default Re: help water leak
My first guess would be the heater core.
Old Nov 26, 2011 | 04:14 PM
DPancoast's Avatar
Does the rear spare tire area have water in it?
Old Nov 26, 2011 | 04:47 PM
nus_dogg's Avatar
First of all before blaming the heater core, does it smell like coolant on the inside?
Old Nov 26, 2011 | 07:00 PM
bdmlilburn's Avatar
if it was coolant from the heater core im sure the smell would be obvious and you would eventually overheat due to loss of coolant. i think i remember someone talking about some sort of drain for the roof coming down the passenger side a pillar area which would be letting rain water in the cabin.
Old Nov 26, 2011 | 08:26 PM
nus_dogg's Avatar
It's gotta be the A/C drain.
Old Nov 26, 2011 | 10:45 PM
nazd41's Avatar
If it’s non of the above and she has a sunroof, check the sunroof drain tube. It could be blocked or disconnected. I would also check the cabin intake cowl (the black plastic piece below the windshield where the wipers connect) these seem to be a common places for leaks on the passenger side. You would most likely notice these after rain or washing the vehicle.
Old Nov 27, 2011 | 01:52 PM
exb18c1's Avatar
Old Nov 27, 2011 | 09:01 PM
honda01civ's Avatar
first off its def not the heater core. and where the drain tube for the sunroof?
Old Nov 27, 2011 | 09:50 PM
nazd41's Avatar
The drain tube runs down the passenger side pillar. Where the sun-visor connects. If I remember correctly it runs under the dash and out the frame behind the front fender near the front tire. I will try to post some links. If not, do a search for "front passenger floor wet" this should bring up good the previous posts.
07AccordBC
May 4, 2012 12:13 AM
Dekorum
18
Sep 28, 2010 07:55 AM
FuNkDrSpOt
Dec 28, 2009 08:21 AM
phantomgreyhatch09
Sep 19, 2009 01:45 AM
hOndafienD 04
Dec 9, 2004 11:13 AM
