B16b intake question.
Old Nov 26, 2011 | 11:31 AM
B16bcivicsi's Avatar
Default B16b intake question.
Hello first post here. I have a 1999 civic si with a ctr b16b I'm looking for a cold air intake I've searched and found an aem hybrid intake part # 21-5007c. My question is should I just put a k&n panel filter and call it a day, or is this aem hybrid intake worth it? Thank you all in advance
Erik
Old Nov 26, 2011 | 11:35 AM
grumblemarc's Avatar
The Grumpiest
Default Re: B16b intake question.
Short Ebay pipe and a velocity stack. You can even stick a K&N filter on that. Otherwise a drop-in filter in the stock airbox would do it.
Old Nov 26, 2011 | 11:44 AM
Ok thanks for the reply. If anyone has anything for sale let me know.
Old Nov 26, 2011 | 11:50 AM
A lil 2.3l action's Avatar
cold air intake. the motor is a top end motor. you will notice more of a difference with that than a short ram.
Old Nov 26, 2011 | 11:56 AM
Well with that aem hybrid intake it says b16 or b18c5 swap .. Does this make a difference? And will this fit my b16b? I don't want to make a 200 dollar mistake.
Old Nov 26, 2011 | 12:02 PM
b18c5 is the type r. which has the same manifold design as the ctr b16. (not like the gsr)
so I dont see a difference. do they show any pictures
Old Nov 26, 2011 | 12:03 PM
Libertariat's Avatar
Ek Forever y0!
If you'll browse the all motor forum you'll learn this very quickly:
99% of the time, on any engine, a short ram intake with a velocity stack is the best across the board intake for ANY ENGINE.
3" tube + Velocity stack and a good filter.
The only way to improve upon this is to tune the short ram at varying lengths. Other options are to have a 4" tube stepped to a 3.5" tube, stepped to a 3" tube at the Throttle body.
Cold air intakes are NOT the best intake, simply. Short rams generally perform better on all engines.
Old Nov 26, 2011 | 12:11 PM
Okay, I'll look around and piece it together. A short ram will be better for the lake Tahoe winters. Thanks to all who helped.
Old Nov 26, 2011 | 12:15 PM
The Grumpiest
Explain.
Old Nov 26, 2011 | 05:01 PM
EsotericImage's Avatar
Retired Moderator
Spending 200.00 on a metal tube and filter is just a mistake period! A tube is a tube no matter who's name is stuck to it.
Old Nov 26, 2011 | 05:04 PM
fastlane2
May 1, 2010 10:35 PM
kelviiv
Sep 19, 2008 09:33 AM
mitcho
13
Jul 12, 2007 05:39 PM
Greg James
Sep 7, 2004 05:27 AM
Stefndogg
Jun 3, 2004 06:46 AM
