98 Civic ex problem with the remote starter.
Anyone have ever put a remote starter in a 98 civic ex? I'm having problem won't start. I need to by pass the manual part. Which I'm lost and so far I got
Remote Start, (H3) 10-pin connector
H3/1 - Pink - Ignition 1 input/output = connected to ign 1 Black/Yellow wire on ignition switch
H3/2 - Red/White - Fused (30A) Ignition 2/ flex relay input 87 = connected to white wire (12v batt wire) on ignition switch
H3/3 - Orange - Accessory output = connected to White/Black wire on ignition switch
H3/4 - Violet - Starter output = i cut the Starter Black/White wire in half and connected this violet wire to the black/White starter wire on the car side
H3/5 - Green - Starter Input = i cut the Starter Black/White wire in half and connected this green wire to the black/White starter wire on the Key ignition side
H3/6 - Red - Fused (30A) Ignition 1 Input = connected to white wire (12v batt wire) on ignition switch
H3/7 - Pink/White - Ignition 2/ Flex relay output = connected to the Yellow wire (Ignition 2) on the ignition switch
H3/8 - Pink/Black - Flex relay input 87A Key side (if required) of flex relay = not connected (not sure if we need to or what it does)
H3/9 - Red/Black - Fused (30A) Accessory/Starter input = connected to white wire (12v batt wire) on ignition switch
any info would be thankful.
b16_madman
12
Jul 28, 2004 05:39 PM
