Mini-me headgasket issues
Ok, I ripped the d15b2 out of my dpfi ef to build myself a mini-me. here are the parts:
z6 head
z6 HG
z6 timing belt
b2 water pump
obd1
I was getting all of the head bolts lined up, when i saw that the two head bolts on the intake side by each end of the head were blocked off by part of the headgasket. Its covering about half of the holes for the bolts. the other 8 bolts just slid right in. any ideas? maybe the parts store gave me the wrong gasket? I'll take pictures in the morning and try to post them.
EDIT:
#8 & #10 are the ones blocked off by the headgasket. I hope this helps at least a little bit :/
z6 head
z6 HG
z6 timing belt
b2 water pump
obd1
EDIT:
Is the gasket lined up with the dowel pins? B2 head bolts should work no problem with the z6 gasket. All D series holes are the same. Everything you listed is correct.
streetlegal gocart
Aug 18, 2003 08:29 AM
lsvtec101
Mar 21, 2003 06:04 AM
