Bisimoto 3.6 D16Z6 Cam V2V Clearance With +2mm Valves
Hey Guys, just bought the Bisi 3.6 Cam for my Z6 and I was wondering if anyone knew if +2mm on the Intake and +1mm Valves on Exhaust would have clearance problems, or if I would need to get valves closer to std size?
Thanks a bunch!
Thanks a bunch!
That's some serious valve area with such a small bore. Gotta be pretty heavily shrouded around 1/4-1/2 of the valve. Only thing you can do is assemble it and check man. You gonna take someones word and gamble the motor? Rearrange the pins in one rocker assembly to engage vtec on one intake valve, then check the click clearance....only way I'd trust it is to do it myself.
Bisimoto does also carry over sized +2mm intake in stainless steel and +1mm exhaust in inconel for turbo applications as well Bisimoto Pro-springs with titanium retainers which have been designed and tested for Bisimoto aggressive camshaft profiles like the Level 3.6 Turbo camshaft.
mejim707
May 15, 2009 09:52 PM
idriveadelsol7
12
Dec 12, 2005 03:53 PM
EGinNY
13
Feb 20, 2004 10:34 AM
