No clutch pressure
Okay so I was driving my car yesterday going to shift from first to second gear and I pressed the clutch in and no pressure at all pulled over thought maybe i should bleed the lines bled the lines nothing.. replaced slave cylinder bled the lines again still no help.. there is fluid flowing from the master to the slave and the slave cylinder is actuating into the knuckle but doesn't retract all the way without pulling the clutch pedal out.. I've checked the lines and doesn't appear to be a leak any help would be appreciated, thanks
have someone hold a pry bar against the clutch fork and push the pedal. if it's stiff as **** and and there is pressure on the bar the clutch is shot. if the pedal will go down and he could hold the fork in place the master cylinder is shot
if your master has never been replaced it's very common at this age for it to go. if it is done for buy a new one from acura! similar price to the parts stores for oem quality
x2 on that OEM CMC .. Autozone and other after market manufactures make really cheap quality ones and they will go bad as well in no time. plus the OEM one doesn't need to be adjusted so you still get the same pedal play as stock with no worries of having your clutch wear prematurely (happened to me once because I forgot to adjust the pedal)
sounds like a throw out bearing that came off the fork, broken pressure plate or something of the sort. if the fork has travel and you can feel it work via the pry bar trick, think it out.....what's left?
Pandahatch
12
Aug 24, 2004 07:48 AM
