F22b1 head with f22a6 cam?
The F22B1 is a VTEC head and the F22A6 is non VTEC. Therefore, I would assume that it would not work as the VTEC rocker arms and non VTEC camshaft lobes would not line up properly.
I would ditch the B1 head and try to find a 90-93 F22A* (PT3) head. F22A1, A4 & A6 heads are the same casting number (PT3) the difference between them is in the valve train. However, If you are stuck on the SOHC VTEC, I would save up and buy an aftermarket cam.
Best bet would to be to contact Bisi, Delta or Web. Delta and Web have thousands of grinds to suit any build that you could conjure up. They may have a grind that suits your budget & build.
igo4bmx
Jun 30, 2004 12:27 PM
