95 Civic EX Coupe Part out, done with civics for awhile
So my car was stolen and stripped recently, no money from insurance, just trying to make back some of the money I put in it. Car was previously turboed, although everything related to that is more or less gone. Here is a preliminary list of what is left, all prices OBO. Further down are some other parts I have had in my room or shed, I'm not done with Hondas, but at least done with civics for a bit... check back often, more will be added as I am able to get pictures of everything.
Certifit hood unpainted $40
Walbro 190lph high pressure pump $40
Gas Tank, good cond $50
Unlisted parts already sold:
driver airbag
driver side fender
driver side headlight
driver side seat belt
Corner lights
Carpet
Trunk carpet/felts
Antenna block off
Pass side AC vent
Hood release cable
Driver side mirror cover
Upper driver side door hinge
Taillight harnesses
Wiper Switch stalk
Front bumper Bar
Rear Bumper Bar
Windshield washer bottle/pump
Dash harness
Wiper arms
Any other misc parts you want make an offer!
BONUS STICKERS: Buy something and if you want one of these stickers its yours FO FREE YO! otherwise give me a quarter or two lol, $5 for the bisi plate frame
Alpine CDA-9857 Head unit, working, AM/FM Radio, CDs and MP3 CDs, iPod and XM Radio ready. Includes the unit, face plate, face plate case, cage, original owners manual, professionally soldered harness to fit 86-95 civics, and maybe others. $150 SOLD
Integra front brake upgrade on EX knuckles with new (month old) bearings on both sides with good rotors and pads $100 SOLD
Integra Rear brake upgrade (trailing arms with year old trailing arm bushings, calipers, good rotors and pads, ebrake cables and brackets, 40/40 prop valve) $200 SOLD
1 inch master cyl with integra booster with new line bent and flared to fit civics etc. $40 SOLD
Goodrich SS brake lines $50 SOLD
Clifford 50.7x alarm system, with add on tilt sensor, glass break sensor, and back up battery. All professionally soldered and heat shrunk, diode isolated sensors. Set up for remote start and includes remote relay pack. 1 mile range! Tested working before it was pulled from the car. Main unit and accessories are all mounted to a Plexiglas plate and wires were extended so that it could be stealth installed in the rear quarter panel. Includes LCD key fob and min screamer siren. $150
Honda ECU chip kits, 9x DIP sockets, 3x ZIF sockets, 12x SST Chips, 9x 74HC373 chips, 18x .1 uf capacitors, 9x 1K resistors, 9x Data logging headers. $120
Moates Burn1 chip burner includes USB cable (not pictured) $50 SOLD
Passenger side fender Gloss Black $40
OEM Passenger side headlight without corner light, no broken tabs, Sylvania Silverstar bulb $30
Trunk no lights $50
Tail light set, no leaks $50
Doors with power windows, mirrors and locks, no interior panels $100 each SOLD
5 speed pedal set up, including clutch master cyl, perfect for your manual swap! $40
14mm GSR rear sway bar with brackets, bushings and end links $40 SOLD
22mm Civic EX Front sway bar with brackets and Energy suspension end links $40 SOLD
Power steering rack with 4 month old inner and outer tie rods $150
EG Sub frame with bolts $100
Integra Rear lower and front upper control arms with Black energy suspension bushings in all locations (Integra rear LCA with sway bar holes) $50 SOLD
Set of 4 civic steel wheels with 2 season old firestone winterforce tires, at least a season or two left in them $150 SOLD
Set of 4 steel wheels with assorted tires, good tread, 185/75R14, 2x Pro Meter, 1x Dunlop, 1x Prime Well $100 SOLD
Rear harness, uncut, $20 all other harnesses pictured are sold
Interior fuse box $20 SOLD
Under hood fuse box $20 SOLD
Lock control unit $20 SOLD
Working blower assembly (fan and in/out control, willing to separate) $30
Heater core, no leaks, with control assembly $40
Temperature control and blower harness for A/C $20
SRS Harness $20
SRS Computer $30
SRS/Horn clock spring $40
Passenger Airbag black $30
Working Cruise control actuator $20
Cruise control Computer $20
Cruise Control Buttons $10
Light stalk $10
Seats, front and rear, no obvious stains, 2 holes in driver’s seat, make an offer
Undamaged interior pieces, black, Left and right door sills, dead peddle, fuse box door, ash tray, forward center cover, rear right panel: make an offer on individual pieces or take them all
Infinity Reference Series 5022i Speakers, securely mounted to OEM civic speaker mounts, and includes the Infinity grills, and original owners manual. Never amped up, never over driven. Sound great with great mids and highs, with highs boost button and positionable tweeters. (DOES NOT INCLUDE OEM GRILLS AS PICTURED) $40 SOLD
Pair of 2000 Civic Si Rims, with BFGoodrich Drag Radials. Began stripping the clear coat off of them, so not to pretty, but the tires have plenty of life on them. Hold air fine. $75 SOLD
Skunk2 D series cam gear in silver, BNIB, never installed $75 [SOLD]
Clean D16z6 Intake manifold and throttle body, with all sensors $30 SOLD
D16z6 head, good valves, checked for flatness $100
Civic EX 7/8th master cyl and booster $30
Stock civic springs $20
D series civic axle cores $20
Innovate Serial adapter, also includes serial termination plug (not pictured) $5
Greddy 3bar map sensor $40
Energy suspension bushing kit for Rear civic LCA $20
Generic Radio antenna and 2x 2ft extensions $5 each
8 gauge amp wiring kit with power, ground, RF fuse holder, 4x 60 amp fuses, RCA cable with built in remote wire $20
Misc parts below, make an offer.
Drum brake prop valve, stock d series shifter, T25 SS turbo gasket, 40mm D series diff, 40mm d series transmission internals (all good except for bad counter shaft bearing surface), civic rear LCA’s with good bushings, civic rear UCA, civic rear toe arm, OBDII d series TB, Honda TB gasket, clutch fork, tranny bracket, OEM civic fuel pump, D16z6 pistons good shape, 2 sets of D16z6 injectors, z6 upper exhaust manifold, OEM fuel rail.
driver airbag
driver side fender
Corner lights
Carpet
Trunk carpet/felts
Antenna block off
Pass side AC vent
Hood release cable
Taillight harnesses
Wiper Switch stalk
Front bumper Bar
Rear Bumper Bar
Dash harness
Wiper arms
Trunk no lights $50
SRS Harness $20
SRS Computer $30
Light stalk $10
BUMP, Most the the parts are ready to ship to you right now! Lets make an deal! Let me know so I pull it before it goes to the scrapper!
Thanks for the bump!
A Bunch of harness stuff, sway bar, and body parts sold today. Get your parts today, before they are gone!
so you had an alarm hidden in the Qtr panel area with backup battery and the thieves got the car? what happend did they tow it? sorry for your loss man.. im actually in the process of getting a stealth alarm install, but am in fear of some one towing my car away...
Yeah the one thing I never got around to doi9ng was hiding the hood cable, I think they pulled that which set off the alarm, and then disconnected the battery and ran, waited for the backup to die and then towed it away.
cpl rampage
Northeast (Sales)
19
May 10, 2013 07:09 PM
92EG8
23
Jun 4, 2007 05:18 PM
