clutch cable issue? need advice
ok so i recently bought a 89 sedan, it needed a new clutch so i changed it bought a new clutch cable. for some reason its having a issue going into gear. ill adjust the clutch cable and it last for like a couple hours of driving but before u know it im struggling to get it into first. my clutch pedal assembly seems to be a little off like the clutch pedal is bent to the side a bit. idk if that may have something to do with it. but thats my issue any idea on what the issue can be ?
also i thought i would ask i heard that u can use a da rear t bracket to throw a b series swap into my sedan. someone else told me i had to use the driver side bracket as well. feel free to clear that up as well.
thanks
thanks
