96 Honda Accord vtech solenoid wires
Old Nov 24, 2011 | 08:31 PM
tlester97's Avatar
Default 96 Honda Accord vtech solenoid wires
I have a 1996 Honda Accord 4 Cylinder VTech.. Where the vtech solenoid is there is a sensor about an inch below it..I need to know what hooks to that sensor and what wires run to it? Mine has the sensor but no wires, not even the plug that hooks to the sensor. So I need to know what they are and where theyre at??
Old Nov 24, 2011 | 08:37 PM
nus_dogg's Avatar
Default Re: 96 Honda Accord vtech solenoid wires
It's VTEC and not VTECH. That sensor you're talking about is called the VTEC Pressure Switch(VTS). The wire attaches to the VTS and goes straight to the ECU in it's correct pin slot. That pin slot would be in Connector "C" in slot number 15 and the wire color would be Blue/Black according to the OBD2A ECU Pin Out.
Then, here's another link I found that is very useful too: http://www.innovatemotorsports.com/r...nda_Accord.php
Old Nov 25, 2011 | 04:06 AM
GhostAccord's Avatar
That's weird! My OBD2 wiring diagrams do not show the VTS in C15. it's blank and it does not show any oil pressure switch on the VTEC assembly ether. I don't think the 96+ Accord uses a VTS signal from the VTEC assembly.
cpayne5
Dec 8, 2015 06:04 AM
rao_manoj2004
Apr 15, 2013 07:21 PM
Quade
Oct 14, 2008 12:56 PM
C_I_V_I_C_V_T_E_C
Sep 15, 2007 04:28 PM
type-t
Aug 19, 2004 06:39 PM
