98 Civic - pulsing lights and speedometer goes crazy
Old Nov 24, 2011 | 08:06 PM
GDean's Avatar
Default 98 Civic - pulsing lights and speedometer goes crazy
Hey everyone, just got a 98 hatch today,
I did a search for my problem, found what people thought it would be, and fixed those issues..
anyways, symptoms, pulsing lights, all of them in the car, down to the radio, speedo was going crazy and only working part of the time.
Was driving on the freeway just a bit ago, and the cluster and all the lights for the climate control/radio/headlights were pulsing really bad, and was VERY noticable... so I turned around and came home, but I noticed, when I would step on the gas a good amount, the car would cutout and act like it didn't want to go and the odometer/speedo wouldn't even register.
I need this car to be fixed ASAP, what would be causing this..
keep in mind, I replaced fuse 15 with a 7.5, and rewrapped the wires under the intake manifold, AND cleaned the grounds/contact points.
WHATS GOING ON!?!?!
Old Nov 24, 2011 | 08:14 PM
Former User's Avatar
Default Re: electrical issue?
If fuse 15 is not blown, test the alternator.
Old Nov 24, 2011 | 08:20 PM
bradley's Avatar
Bad ground, sounds like. Check all of your grounds, clean them, re-tighten them. This exact thing happened on my old '89 CRX and it took me forever to figure it out... TUrns out it was the body-to-engine ground.
Old Nov 24, 2011 | 08:26 PM
GDean's Avatar
Have the car on the trickle charger, and I may have missed a ground or two, where exactly is the engine to body ground...
Also, the pulsing lights didnt start until earlier when I left a stop light and accidentally spun the tires
Old Nov 24, 2011 | 08:29 PM
bradley's Avatar
When you spun the tires, you could have simply moved the engine around a lot and loosened the ground. I've seen stranger things happen.
Someone will have to chime in as to where the body/engine ground is on sixth gen, I'm not too familiar with them.
Old Nov 24, 2011 | 08:41 PM
GDean's Avatar
Ahh ok, thanks for the help bradley
Old Nov 25, 2011 | 12:10 AM
GDean's Avatar
so I did a test and pulled my negative battery terminal off while the car was running, and the idle bounced around like a jackrabbit.....
Old Nov 25, 2011 | 04:00 AM
Please create thread titles that summarize the tech problem -- edited.
Avoid doing this^ test as it may damage your electrical system.
Old Nov 25, 2011 | 07:52 AM
GDean's Avatar
Default Re: 98 Civic - pulsing lights and speedometer goes crazy
Will be testing the alt today
Old Nov 25, 2011 | 11:21 AM
Linked's Avatar
an alternator with an improperly working voltage regulator can be a culprit for problems like this
Old Nov 27, 2011 | 11:45 AM
GDean's Avatar
Changed the alt, that stopped the pulsing, but now the speedo doesnt work and my c.e.l is still on, pulled the codes at schucks, it gave me these.. P0135 and p1298... What are these codes?
Old Nov 27, 2011 | 11:59 AM
If you reset the ECU, do both codes return?
Old Nov 27, 2011 | 12:15 PM
GDean's Avatar
Meaning pull the battery for 30 seconds? If so then yes, and speedo still doesnt work
Old Nov 27, 2011 | 12:27 PM
Remove the hood Back Up fuse for a minimum of three minutes. Then check whether both codes return.
Old Nov 27, 2011 | 01:08 PM
GDean's Avatar
Pulled the fuse, will report back in a bit
Old Nov 27, 2011 | 01:15 PM
hunan beef's Avatar
What chassis and engine?
Old Nov 27, 2011 | 02:17 PM
GDean's Avatar
98 hatch with a y7, pulled the fuse and then put it back in after half hr, c.e.l. And codes came back
Old Nov 27, 2011 | 02:50 PM
Is fuse 15 blown?
Old Jun 22, 2016 | 11:06 AM
efekek's Avatar
WHATS GOING ON!?!?!
Did you ever solve this or did the alt fix it i took mine out tested it and it passed I haven't put it back in yet but if like to hear how you fixed it....sorry for the post on such an old thread
Old Jun 22, 2016 | 11:24 AM
Check fuse 15 and the fuse 15 TSB.
paowa
Lighting
Apr 2, 2009 05:19 AM
bizzd
Aug 31, 2006 11:29 PM
4doorcivic16
May 19, 2006 06:54 AM
Rayog21
Sep 21, 2005 08:38 PM
