2000 coupe b18b nitrous help ?
i have ek whit stock b18b swap whit only basic bolt-on : aem sri and custom 2.5 no cat exaust
now i check for nitrous and whatch for the safe shot from zex the kit come whit 35 shot did you think this 35 shot will drop my time in 14s in 1/4 ?
for reability i need new clutch did you think xtd 6 puck whit spring will tuff tue run ?
now i have xenocron harnes whit virgin p75 did you think street tunig will be safe for DD ?
whit low budjet what is the best type r or dc header ?
no a 35 shot of nitrous is barely any bump in hp and very weak. make sure you research and read thoroughly about it. nitrous can blow the intake manifold off if u get an air bubble in the line the first time u spray. also u can melt rings if you hold nitrous more then 15 seconds. nitrous has a lot of safety features that are worth investing in. make sure you run colder spark plugs. without a bottle heater or keeping the bottle warm the pressure in the bottle will drop and it will not be very efficient. you are gonna need at least a 75 shot of nitrous to get yourself in the 14's with an ls motor. im running a stage 3 xtd sprung clutch in my turbo z6 and run 14's and it holds fine. these clutches are hit or miss. dc header would be fine. Nitrous is not a very safe power adder many things could go wrong and blow your motor instantly. for a daily it would be ok but i don't advise using it or leaving it in the car on a super hot day the tank can blow off inside the car if the tank over pressurizes and waste all your nitrous. so if you do make sure u do install and blow down tube that goes outside the car in case this does happen. a basic nitrous kit may be cheap but its definitely not reliable without the safety features. you will have to pay to play either way.
Nitrous is very fun.... But even the 50 shot just feels like an auto matic. Down shifting.....i ran a 75 for 3 years....on avage 2 bottles a month bout 5 months a year. ..... I finally blew it up buy running 2 75shots lol at once.... Just make sure u use good gas....if u want a kit... Message me i got one cheap
