Legend caliper upgrade w/ 28T bracket?
Old Nov 23, 2011 | 07:47 PM
Kennyjai's Avatar
Default Legend caliper upgrade w/ 28T bracket?
Hey guys, so I did a search regarding the 94+ Legend GS 2 piston caliper upgrade but I didn't find much info about the 23T vs 28T brackets on 07' cooper base rotors.
my setup would be:
legend 2 piston calipers
hawk hps pads
mini cooper base 280mm rotors
I have a 2001 integra LS that are on LS meshies. Are the 28T brackets a perfect fit or would I have to grind 3mmm of it off to have rim clearance ? I believe i would have to do this for the prelude rotors, but does anyone know if i need to for the mini cooper base rotors? Thanks!!
Old Nov 23, 2011 | 08:58 PM
Fink29's Avatar
Default Re: Legend caliper upgrade w/ 28T bracket?
I am running this setup. Get the 23t brackets no modification needed. Everything will bolt up.
Fink29's Avatar
Bracket should match the rotor thickness.
Old Nov 23, 2011 | 09:02 PM
Fink29's Avatar
If you want to upgrade the rears get the rsx/ep3 rear caliper w/ep3 rotors. Bolts right on. The only thing you have to do is put your stock ebrake mech onto the ep3 rotors. When you look at them you will know exactly what I mean.
Old Nov 23, 2011 | 09:03 PM
Kennyjai's Avatar
soo are you saying the 28T brackets need to be grinded?
where can i buy the 23T brackets? also, do i need to change the proportional valve and upgrade to a larger master brake cylinder?
Old Nov 23, 2011 | 09:06 PM
Kennyjai's Avatar
i'm planning to buy these from oreilly
http://www.oreillyauto.com/site/c/de...0062&ppt=C0009
Detailed Description
Overall Height: 1.74"
Overall Diameter: 11.01"
Bolt/Holes: 4
Bolt Circle Diameter: 3.93"
Center Hole Diameter: 2.53"
Nominal Thickness: .87"
Discard Thickness: .80"
Type: Vented
Old Nov 23, 2011 | 09:09 PM
Fink29's Avatar
Well I upgraded my civic si to integra 1". You should be fine seeing that you have an integra already. Not 100% sure about the 28t brackets. The grinding issue should be all set seeing that you are running the mini rotors. They are a tad thinner than the alternatives. 23t brackets come on the single piston legends, preludes and make accords. Let me check.
Old Nov 23, 2011 | 09:18 PM
Fink29's Avatar
Get your stuff from rock auto.com
Caliper Brackets Legend ls
$16
Part Number: 141417
Rotors 2007 mini sohc
$22
Part Number: 12134100
Old Nov 23, 2011 | 09:19 PM
Fink29's Avatar
The caliper brackets will come with the brackets, slide pins and hardware.
Old Nov 23, 2011 | 09:51 PM
mark@silbernage's Avatar
I see a lot of discussion regarding removing material from 23T brackets, or using shims with 28T brackets - but only a few on using the 25T brackets, which don't seem to require the removal of metal or shims...
As a good example, cHeck this out: http://cl.acurazine.com/forums/showthread.php?t=783115
Don't know about you but I'm much more comfortable with the idea of assembling things that fit well when dealing with critical safety parts in high-stress applications.. if possible! ; ' ) That, and I don't have a machinist handy.
Keep us posted, plz - and take some pics when you're done.
Mark
Solscud007
Dec 8, 2004 10:00 PM
JustLooking
Jul 9, 2003 09:01 AM
Veil_Side_
Jun 29, 2002 11:07 AM
