Rear disc w/4 lug???
EP3 rear brakes are far from difficult to find. There were a ton of them out there, and a lot of EP3 owners who still have 4-lug upgrade to the more modern 5-lug setup.
If you can find a five lug rear disc swap set, you should be able to convert the five bolt wheel bearing and hub assembly to a four bolt, along with changing the five bolt rotor to a four bolt rotor. I believe everything else (spindle, caliper, and caliper bracket should be the same) You could likely find white box rotors and wheel bearings for under $200 usd.
Acura EL is not a common vehicle in the states, and it simply wouldn't be worth the cost alone of shipping the parts from Newfoundland-to-Florida. Better off using EP3.
pinoyboy204
Jun 25, 2012 04:32 PM
