Throttle Cable 1/2 Inch too long
Old Nov 22, 2011 | 11:31 PM
MoreCowbell's Avatar
Icon3 Throttle Cable 1/2 Inch too long
I have no more adjustment in my throttle cable next to the throttle body. 99 civic with gsr swap.. Changed the throttle body for a bigger one and also used a throttle body spacer which is now giving me this issue. Advice please thanks!!
Old Nov 22, 2011 | 11:32 PM
apexi_rsx's Avatar
Default Re: Throttle Cable 1/2 Inch too long
you can change the throttle wheel on the tb to a bigger one that will shorten it up some i know my automatic dx tb had a bigger wheel on the tb. i had this problem on mine
Old Nov 23, 2011 | 12:35 AM
Ahh nice idea. Anything I can do with the slack near the gas pedal? Maybe a spacer of some sorts there?
Old Nov 23, 2011 | 02:12 AM
apexi_rsx's Avatar
should be able to take care of all the slack in the cable with the adjustment screw after you change the TB wheel
Old Nov 23, 2011 | 04:31 PM
Top for more suggestions
Old Nov 23, 2011 | 10:38 PM
halp
Old Nov 24, 2011 | 07:18 AM
germanturtle's Avatar
custom length throttle cables are available
Old Nov 24, 2011 | 12:23 PM
ssmtyper's Avatar
if you have a ACE hardware where u live, go there and got to where all the billions of nuts and bolts are.... near that area will be some rubber washers of ALL diffreant shapes and sizes, YOu should be able to find one just right or close enough, the use as a spacer where the wire meets the pedal... done this before and works great feels stock, and no one will ever see it!!
Old Nov 24, 2011 | 12:28 PM
Jdubbs6101's Avatar
Buy a different throttle cable I thought the si cable was a different size than the reg ones not 100% sure though
Old Nov 24, 2011 | 10:38 PM
This is the one I will go with, thank you. Also thanks to everyone who chimed in
boostedteg1203
Jan 14, 2010 01:17 AM
wade
Mar 18, 2009 01:14 PM
Slow_h22
Aug 1, 2004 03:25 PM
NatrualAsp VTEC
Sep 17, 2003 05:19 AM
