itr im
Old Nov 22, 2011 | 08:23 PM
Gsrsi's Avatar
Default itr im
whats the difference between the itr and gsr mani. I'm a/m.
Old Nov 22, 2011 | 08:32 PM
doood's Avatar
been there done that
Default Re: itr im
the itr manifold is single plenum with shorter fatter runners for better high rpm flow. they are not interchangeable between heads.
Old Nov 22, 2011 | 08:35 PM
Gsrsi's Avatar
Default Re: itr im
thank you. lol I'm kinda new so i appreciate the solid answers. what up graded mani should i go for and if i do should i up my injectors and my rail.
Old Nov 22, 2011 | 08:39 PM
B20ztek's Avatar
Default Re: itr im
Old Nov 22, 2011 | 08:43 PM
doood's Avatar
Default Re: itr im
no one can answer that for you. do your own research and come up with your own conclusions.
Old Nov 22, 2011 | 09:17 PM
mark@silbernage's Avatar
Default Re: itr im
Actually, if you're not really building out the motor (either N/A or turbo) - you're doing it more for 'pretty' than performance aren't you? The dual runners give you an edge by being tuned for low-end (long runners) AND top-end (short runners).
If you just grab a Skunk (or ?) intake your narrowing down the range the manifold serves you well. Maybe OK if you want mostly hi-revs.. or turbo.
I think that's what the research comment is about.
You may need to read before you have a goal (based upon perf and $, for example).
You need a goal before you start buying parts...
Otherwise, you end up with a mish-mash that may work against itself and cost you both money AND performance.
The stock GSR is a rather nice setup out of the box... ; ' )
Mark
Godspeed07
11
Jul 11, 2007 02:04 AM
my ride
Jun 17, 2004 10:41 PM
A.S.I.M.O
Mar 25, 2004 09:18 AM
typRpwr1161
Jun 21, 2002 04:36 AM
Todd00
59
Jun 22, 2001 11:14 AM
