98 Civic - 15A dash fuse 13 blows
Old Nov 22, 2011 | 07:45 PM
Kyle Atwood's Avatar
Default 98 Civic - 15A dash fuse 13 blows
I'm have a very frustrating and weird problem
My 15a ecu fuse under the steering wheel keeps blowing, and it's not immediate. It's happened once a week but twice today.
This is my daily so I need to figure it out ASAP.
I have not messed with the workin under the dash.
I have a 98 civic that was automatic.
Now it has an h22a manual swap in it with a hasport wiring harness and an s300 p28.
Old Nov 23, 2011 | 05:11 AM
Former User's Avatar
Default Re: Ecu fuse problem.
There are several 15A fuses in the dash fuse box. Which one?
Old Nov 23, 2011 | 06:59 AM
Default Re: 98 Civic - 15A dash fuse blows
It's fuse number 13 on that chart. My SRs light is on btw... It just came on randomly though..
Old Nov 23, 2011 | 08:20 AM
Currently, if you turn the key from off to ON(II) several times, does fuse 13 eventually blow?
Old Nov 23, 2011 | 08:44 AM
Well, it only blows while I'm driving it, but I'll try that and tell you.
Old Nov 23, 2011 | 08:47 AM
If you get fuse 13 to blow the way I mentioned, you will be able to pinpoint the short. Otherwise, I'll mention that a common cause of fuse 13 blowing is a bad fuel pump.
Old Nov 23, 2011 | 09:09 AM
The fuse didn't blow when I did it repeatedly for like 5 mins lol.
And literally a month old walbro 255 :/
Old Nov 23, 2011 | 09:39 AM
It could be the main relay or a bad wire, but my bet would be on the fuel pump.
Old Nov 23, 2011 | 10:45 AM
I can't imagine it being a bad wire, I haven't messed with anything under the dash.
I'll replace the main relay soon.
If its the fuel pump will it happen more frequently till it fails all together?
When the fuse goes out it doesn't power my ecu, I didn't know it was affected by the fuel pump.
Old Nov 23, 2011 | 12:17 PM
Fuse 13 does not directly power the ECU. As shown in the diagram below, fuse 13 provides voltage directly to the fuel pump.
Old Nov 23, 2011 | 12:54 PM
Ok so when the fuel pump doesn't come on neither does the ecu?
I can tell because the s300 lights don't come on
Old Nov 23, 2011 | 01:39 PM
This could possibly indicate a main relay problem.
Old Nov 23, 2011 | 03:08 PM
That's what I'll replace next. It's blowing instantly now and I'll probably have it trailered home. When I put another one in it, the walbro primes like normal but when I start to move the car just quits and ecu shuts off.
Old Nov 23, 2011 | 03:09 PM
I missed this^
Jump the service connector to pull the SRS code (see FAQs sticky). What code is thrown?
Then unplug the SRS control unit to see whether this prevents fuse 13 from blowing.
Old Nov 23, 2011 | 04:33 PM
I'll do this as soon as I can get the car home and let you know what happens.
Old Nov 23, 2011 | 06:32 PM
Mobeious's Avatar
happened to me .. ended up being a wire on the downstream 02 sensor rubbed on the exhaust heatshield and grounded out
HondaMike323
Oct 16, 2014 03:18 PM
SlvrJdm
Lighting
Mar 9, 2013 04:34 PM
harley06
11
Sep 20, 2005 01:44 PM
cheefer
Jun 12, 2005 07:29 PM
