greddy informeter ob2 engine monitor $200
Old Nov 22, 2011 | 03:31 PM
217sportcompacts's Avatar
Default greddy informeter ob2 engine monitor $200
got this for my car and it wont work on it, only works with obd2 cars. only took it out to try and hook it up. has box manual cables meter mounting etc. this is the info from greddys website. $200 + s&h send me a email @ modatrd03@yahoo.com or text 8five0three5six84two1
Designed with a compact plug and play color LCD display, the Informeter allows you to monitor, set warning points and datalog your vehicles performance though it's own OBD sensors. Select through important signals like Speed, Tach, Temps, Air Flow, Voltage, etc. (up to 25 channels), to monitor. The easy to use navigation menu allows you to select between various screens and displays: Digital, Analog or Bar Graph and 2ch, 3ch, or 6ch screens. You can also set warning points and pre-warning points, which will alert you with audible and visual highlights of important readings. Datalog up to 6 channels of data, and replay them. This is great for tuning. In addition to being functional the Informeter is also infinitely fashionable. Seamless changes in backlighting color, GReddy signature wall papers and colored backgrounds, along with a clear bezel to install colored face plates or even custom face plates, offer a endless options to match any vehicles interior. And to aid in mounting the unit can flip the display 180 degrees to free even more options. The GReddy Informeter is a key tool for all; beginners to pro tuners.
half jdm
Jan 30, 2009 02:27 PM
JJ-Built
Aug 27, 2007 07:59 PM
sndc5
Mar 15, 2007 06:18 PM
sndc5
Feb 5, 2007 01:54 PM
FabulousSi
Apr 15, 2003 06:32 AM
