what is this part and what does it do?
Old Nov 22, 2011 | 02:53 PM
andyhundley's Avatar
Default what is this part and what does it do?
i have a 95 honda civic dx hatch 1.5 non v tech no abs and i have had this continuing issue with my brakes. https://honda-tech.com/forums/suspension-brakes-54/95-hatch-dx-brakes-sticking-2997832/
i am curious as to what this part does (the white plastic piece that goes inbetween the 2 vacuum hoses that go from the intake to the bottom of the brake booster)?
the brakes will stick to the point where they will be close to being completely locked up but when i unhook the vacuum line from the bottom of the booster the brakes will instantly release and the car will roll. so i was curious as to what the white plastic is for. is it some sort of valve or just a coupler for the 2 vacuum hoses because i dont want to guess on a booster just to find out that it was this part that i posted. thanks
Old Nov 22, 2011 | 03:32 PM
grumblemarc's Avatar
The Grumpiest
Default Re: what is this part and what does it do?
It's the check valve. Did you adjust the pushrod as instructed?
Wdpfreak145
10
Mar 28, 2013 10:48 AM
whited
Aug 6, 2012 12:18 PM
goldfinger93030
Sep 19, 2010 07:33 PM
Da1spaz247
Dec 11, 2007 06:28 PM
junglistgsr
Oct 6, 2001 08:01 AM
