OEM oil cooler (heat exchanger) ; JDM vs. USDM
Old Nov 22, 2011 | 11:49 AM
Pompiuses's Avatar
Default OEM oil cooler (heat exchanger) ; JDM vs. USDM
I just recently bought a used OEM ITR oil cooler, and I noticed that the bolt that came with it is longer than the USDM bolt I already got laying around (see picture). Meaning that the core is thicker. The longer bolt also got a spring mechanism in it which the other don't.
So I was thinking that I may've gotten a JDM version? Is the OEM JDM oil cooler bigger/thicker than the USDM?
Old Nov 22, 2011 | 12:45 PM
Redcoupe's Avatar
Default Re: OEM oil cooler (heat exchanger) ; JDM vs. USDM
My JDM and USDM ones are the same?
Old Nov 22, 2011 | 07:40 PM
killer_Bseries's Avatar
I got a JDM b18c-r block and the oil cooler it came with was the same as usdm one, along with the center bolt.
Old Nov 22, 2011 | 10:36 PM
Pompiuses's Avatar
Do you remember if the center bolt had a spring mechanism in it?
Old Nov 23, 2011 | 09:54 AM
Pompiuses's Avatar
Found out it's from a 1995 GSR motor. Strange that it's thicker than the ITR unit. Hopefully it cools better. I studied the spring mechanism inside the center bolt, and it looks like it's there to make sure oil gets forced into the cooler through the holes in the bolt as well as allowing some oil to pass straight through the bolt.
Old Nov 23, 2011 | 09:55 AM
racebum's Avatar
can't remember the spring either but mine was also a direct fit jdm to usdm with the oil cooler
Old May 5, 2013 | 11:18 PM
Badweather Jim's Avatar
Guys a little help, I'm trying to replace this part on my H22A. How can I find the part number on Rockauto? TIA.
Old May 9, 2013 | 03:45 PM
racebum's Avatar
go to the dealer and not rock auto?
JDM97dc2R
Oct 21, 2011 03:46 PM
Drumatik
Dec 16, 2006 09:53 PM
DarkBB4
Aug 31, 2004 07:17 PM
BIGGIDYBOB
Jan 30, 2003 02:57 PM
Screamer
Oct 25, 2002 07:02 AM
