Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Honda Civic SI 2008 won't start up
Old Nov 22, 2011 | 10:49 AM
skyinfire305's Avatar
Default Honda Civic SI 2008 won't start up
Hello, Im new to this forum. I have the following problem. I want to buy a crash honda civic SI 2008 so I can rebuild it for myself. I am looking at the iaai.com insurance auction website and I see a Civic with a hit on the right door with 54k miles on it but it says the car won't start. I dont think the problem is electrical because I can see the odometer showing the actual mileage of the car. I would like to know what could be the worst case sceneario for this car not to start and how much would it cost to fix?? This car was only own by one person according to autocheck so I am guessing it was still under warranty. I appreciate any information you might tell me. The link to the car is this:
https://www.iaai.com/Vehicles/VehicleDetails.aspx?auctionID=11092521&itemID=1182 8541&RowNumber=1
Old Nov 22, 2011 | 03:34 PM
vladd's Avatar
Default Re: Honda Civic SI 2008 won't start up
It could just be a bad battery. At the auctions, they connect a jumper pack to newer cars to read their odometers if the battery's bad.
Old Nov 22, 2011 | 08:47 PM
thank you for the input but some cars they state wheather the car starts with a jump or not so I am guessing they tried to jump start it and it didnt work. I want to know what is the worse that could happen to the engine and how mucho would it cost to fix it
Old Nov 22, 2011 | 09:47 PM
vladd's Avatar
I don't see where it says that they tried to start it with a jump. If the battery's not the problem, there are like hundreds of different things that could be wrong. Does the motor crank? Does the fuel pump prime? Do the injectors get fuel? Does it build compression? etc, etc. You can go on and on with the questions trying to diagnose a starting problem. Worst case scenario would be bent valves/broken pistons from an overrev, which would require a new engine.
Old Nov 23, 2011 | 06:59 AM
bee guz's Avatar
It could be they don't have the right key with the right transponder and the car shut itself down.
If you think you can do the repair I wouldn't be afraid of the starting problem.
AnnetteMutz
Honda Civic (2001 - 2005)
Sep 12, 2017 03:32 PM
Tywin
Jun 11, 2016 05:52 PM
Steftravels
20
May 25, 2012 12:25 AM
laziebun
Jan 20, 2009 06:05 PM
