Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Civic Ex, Location/Replacement of Knock Sensor
Old Nov 22, 2011 | 08:50 AM
ralphdhall's Avatar
Default 2005 Civic Ex, Location/Replacement of Knock Sensor
I need to replace the knock sensor on a 2005 Civic Ex, 1.7L, Manual 5speed, 2dr. Anybody know where it is located and what I have to do to change it? Anything I need to do after I change it, like do some kind of code reset? Thanks. Ralph
Old Nov 22, 2011 | 09:07 AM
It Wasn't Me's Avatar
Default Re: 2005 Civic Ex, Location/Replacement of Knock Sensor
Unless you're crafty, you'll need to remove the intake manifold to replace the knock sensor. (someone here said you can reach it from beneath the car, but I cannot verify this since I haven't looked)
Torque spec is 16 ft-lbs.
You can just disconnect the battery before you even get started. (I would)
Old Nov 23, 2011 | 03:49 PM
hondatech8798's Avatar
can be reached from under the vechicle... remove the oil filter for a little more room, it's just slightly above it and too the left by the coolant tube and the plug is attached too a small bracket located by the timing cover it's a tight squeeze but it's not too hard too do
Old Nov 24, 2011 | 03:04 AM
lazlong's Avatar
Yeah, it's a bit of a pain to get to from underneath but, I'd rather do that than take off the intake mani.
Old Nov 28, 2011 | 06:27 AM
ralphdhall's Avatar
Thanks.
Old Nov 28, 2011 | 06:31 AM
ralphdhall's Avatar
Thanks.
Old Nov 28, 2011 | 06:33 AM
ralphdhall's Avatar
Thanks everybody. I appreciate the info.
CChong
Jan 16, 2017 02:53 PM
Jimi Hondrix
Jun 5, 2015 08:42 PM
Artcox
Dec 26, 2012 11:27 AM
entails
Sep 28, 2008 10:07 AM
ek-g6
Dec 30, 2007 02:21 PM
