turbo?
Hey guys. so im looking at buying a turbo this thursday guy is giving me a good deal on it 60 bucks. i was just wondering what you guys think of throwing it on an h22a i know the compresion is way high but i was thinking of just running on 5 pounds til i build the block just curious on how you guys think it would hold up??? and just the turbo is 60 bucks i would have to piece the rest together
thanks in advance guys
There's a lot that goes into a turbo system, start researching.
I'm running 10:1 compression on my setup, high compression isn't the issue, understanding what you're doing is.
BTW, 5psi on my setup is 285whp [on a low reading dyno], that's easily +100hp over stock and well beyond what stock injectors will do.
BTW, for $60 for a working turbo, I'd buy it and find out what it is. At the worst you have a really cool $60 paper weight.
I actually have a blown Precision 6262 paper weight, which is basically Precision's version of the GT35.
haha for sure man thank you i mean i know what i need and stuff i mean for 5 pounds you think i need bigger injectors?
Compression text? Your motor got wi-fi or something? LOL
Bigger injectors for 5psi, yes. There are fuel/hp ratio calculators on the web from reputable companies like Garrett, figure out what size injector you need for 250-300 horsepower and add at least 20% to give yourself room to grow.
If I remember correctly, the stock H22 injectors are only good to around 225whp.
FYI, 5psi on an H22 isn't the same as 5psi on a B16. An H22 will create more horsepower, pound for pound than a D or B-series, due to the displacement difference. I'm around 400whp on 10-12psi with 10:1 compression, while my friend has a stock B16 with ~10.6:1 compression needs 18psi to create 400whp, smaller motor, same airflow creates higher boost pressures.
Also, wheel horsepower is only like 80-90% of crank horsepower. This is why an H22 rated at 190-210bhp [at the flywheel] by Honda, dynos between 165-180whp [at the wheels] with no mods [also depending on the dyno].
Bigger injectors for 5psi, yes. There are fuel/hp ratio calculators on the web from reputable companies like Garrett, figure out what size injector you need and add at least 20% to give yourself room to grow.
well you hit the hammer on the nail with that one, cheaper. You pay for what you get...i understand it's a subie turbo...but i mean if you're gonna just build a backyard turbo...you're bound to tear your **** up. So if this kid wants reliable he needs to research....and maybe it's just me but i wouldn't go anything less than a ball bearing turbo.
