Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
STRANGE SOUND COMING FROM THE ENGINE
Old Nov 22, 2011 | 05:58 AM
xsxnosxsx's Avatar
Icon6 STRANGE SOUND COMING FROM THE ENGINE
Hey everyone I recently started to have a problem with my Honda Civic Si 08. The engine (guessing it is the engine), while in gear is doing a rubbing noise. I can usually hear it the loudest while going about 30MPH at 1.3k RPM but it happens throughout the power band. The best I can explain the sound is a rubbing sound for a example a eraser on a paper. The higher in the rev I am, the faster the sounds is. The sound goes away when I remove it from gear. If I am in idle in gear not moving and clutch is engaged there is no sound. Any help? Any Ideas?
Old Nov 22, 2011 | 06:41 AM
bee guz's Avatar
Default Re: STRANGE SOUND COMING FROM THE ENGINE
If I can read your description right, the noise sounds like the trans, not the engine.
I would by looking at the trans fluid, or just change it and see if the sound decreases, I doubt that it will go away but perhaps you can buy a little time.
If your still under warranty I would get to the dealer and have it checked out.
Old Nov 22, 2011 | 07:08 AM
xsxnosxsx's Avatar
Alright. Sounds like a plan. And I am at 41k i am not in warranty anymore, sadly. How much would something like that cost to get it looked at?
Old Nov 22, 2011 | 10:09 AM
eparra83's Avatar
Isn't the powertrain warranty 60k miles/5 years?
Old Nov 23, 2011 | 07:05 AM
bee guz's Avatar
It isn't hard to check the trans fluid any garage with a lift probably would check it for you for a few bucks.
I would ask them to change the fluid if I were you, I am told by members on this site that honda MTF Manual transmission fluid, is a special formula and not to use any others.
It should be around $5 a quart and you need 2 quarts, the job should take no more than 20 min.
AVA
17
Apr 7, 2009 03:59 PM
nacho
11
Jan 29, 2007 10:51 PM
redliner8000
Feb 19, 2004 08:49 PM
