FS: 1991 Civic Si ///Lots of Extras///
Touching My Member
.SOLD
Goods/Mods;
Engine:
B16A
81.5 IL4 Pro-Cast Pistons (US Spec B16A Dome).
OEM Honda Bearings.
OEM Gaskets.
Balanced.
OEM Shot Peened Rods.
ARP Rod Bolts.
Buddy Club Spec 3 Camshafts.
Buddy Club Valvesprings & Retainers.
Buddy Club Valves.
DC Header.
ITR Valve Cover.
Toda Cam Gears.
ITR Intake Manifold.
IL4 68mm Throttle Body.
Blox FPR.
AEM Cold Air Intake.
2-1/4" Crush bent Exhaust w/ ES Tuning Muffler.
Fluidyne EG radiator w/ FAL Fan.
Innovative Mounts.
Cleaned Up Harness.
Hasport Shift Linkage.
Moroso Oil Pan.
Blox Test Pipe.
Transmission:
Y1 LSD Cable Transmission. (Typical high 3rd Gear Grind)
Exedy Stage 1 Clutch.
Competition Clutch Flywheel.
OEM Axles.
Suspension:
ITR Spec Omni Power Coilovers.
ITR Rear Lower Control Arms.
Energy Suspension Bushings.
Suspension Techniques Sway Bar (Front & Rear).
Skunk 2 Front Camber Kit.
Buddy Club Rear Camber Kit.
Innovative Mounts Traction Bar.
Cusco Rear Strut Bar.
DC Front Strut Bar.
DA Front Knuckles.
DA Rear Disc Conversion.
PowerSlot Rotors.
Hawk Pads.
ARP Extended Studs (All Around)
Earl's SS Brake Lines.
Autopower Roll Cage w/ CrossBar
Buddy Club Extended Ball Joints.
Interior:
Recaro DC2 Red Seats
Wedge Engineering Brackets
Momo Tuner 350mm Steering Wheel.
Gutted Rear.
P72 with Hondata S300.
Apexi Rev Speed Meter.
Stealth Install Viper Alarm.
Exterior
Fat Five Wheels.
Front Azenis need to be replaced and 95% Ziexs in the rear.
Bads:
Slight rear damage. (Previous owner backed up into a Lexus. Lol.)
Will come replacement Black Hatch.
Turn Signals need to be Rewired.
Trans does not have Reverse Switch.
Goods/Mods;
Engine:
B16A
OEM Honda Bearings.
OEM Gaskets.
Balanced.
ARP Rod Bolts.
Buddy Club Valves.
DC Header.
ITR Valve Cover.
Toda Cam Gears.
Blox FPR.
Innovative Mounts.
Cleaned Up Harness.
Moroso Oil Pan.
Blox Test Pipe.
Transmission:
OEM Axles.
Suspension:
DC Front Strut Bar.
DA Front Knuckles.
PowerSlot Rotors.
Hawk Pads.
Interior:
Gutted Rear.
Exterior
Fat Five Wheels.
Bads:
dude when I saw the thread title and posted I was like whhhaaaaa WWHHHHYYYYY... Then I saw it said your bros car........ WHEW!... lolz BUMP!
