stock crx random codes hellllp
Old Nov 21, 2011 | 02:26 PM
civicef990's Avatar
Icon2 stock crx random codes hellllp
sooo i got this crx stock motor tranny, pretty much all stock as you can thing....i keep getting random check engine codes and when i fix the codes others come back, i fix those and more will come up i dont know what do to with this car anymore....any answer will help thanks
codes i had and fixed
-3 MAP - manifold absolute pressure sensor
-6 ECT - water temperature sensor
-7 TPS - throttle position sensor
-8 TDC - top dead centre sensor
-10 IAT - intake air temperature sensor
-14 IAC (EACV) - idle air control valve
-16 Fuel injectors
-20 Electrical load detector
the more i fix the more that come up
Old Nov 21, 2011 | 05:08 PM
delsol92's Avatar
Default Re: stock crx random codes hellllp
replace full intake had the same issue
Old Nov 21, 2011 | 06:17 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Sounds more like a power/ground issue or a BAD ECU...
Old Nov 22, 2011 | 06:14 AM
civicef990's Avatar
and it fixed it after that??
Old Nov 22, 2011 | 06:16 AM
civicef990's Avatar
i checked all grounds and power outta the alternator i checked every spot for power and i all seem good
Old Nov 25, 2011 | 06:53 AM
civicef990's Avatar
sooo yeah i replaced the intake manifold and it fixed it...alll codes r gone and no more stupid idle problems
thanks everyone for all answers
CalmPalmTree
May 1, 2015 05:03 AM
vtechjunkie
Apr 11, 2009 06:04 PM
ooregulateoo
Mar 9, 2007 06:57 PM
rookshot06
Mar 20, 2004 07:52 AM
cottagecreep
Jan 28, 2003 03:18 PM
