got some crazy check engine lights on.....
Old Mar 19, 2004 | 10:39 PM
rookshot06's Avatar
Default got some crazy check engine lights on.....
I know taht some of them turned on because of the rip on the downpipe but i'm gettin cel 13,22,41,71,72,73,74....tried lookin on hondata problem codes to see what the 70's were but have no clue.....any of u guys have any idea what those codes are or even if they exist at all????
Old Mar 19, 2004 | 10:42 PM
5STAR3's Avatar
Default Re: got some crazy check engine lights on..... (rookshot06)
i only have it through 65....
i think above 65 is one of those fake codes you get with hondata, seriously
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
Old Mar 19, 2004 | 11:29 PM
hadboosttroy's Avatar
Default Re: got some crazy check engine lights on..... (envision2teg)
arent the 70 ones misfire codes?
Old Mar 20, 2004 | 12:01 AM
gunmetalcivic's Avatar
i got some of the same codes too. i believe they were 72,73,74. they were engine misfire codes. it ended up being a blown piston ring landing.
Old Mar 20, 2004 | 07:52 AM
Red CiViC Hatch's Avatar
Default Re: got some crazy check engine lights on..... (gunmetalcivic)
what is the primary oxygen sensor heater?
Laz's EP
22
Feb 22, 2010 12:09 AM
DA_Boy_626
Oct 3, 2007 06:50 PM
EL MIGGZ
Oct 3, 2007 06:49 PM
ooregulateoo
Mar 9, 2007 06:57 PM
BLuDoHcReX
Apr 3, 2003 07:36 PM
