need help with h22a jdm swap into 93 Del Sol
Old Nov 21, 2011 | 12:01 PM
h0ust0n_del_sol's Avatar
Icon2 need help with h22a jdm swap into 93 Del Sol
well i got this h22a jdm from this guy said it was his sons so he dint now anything about it. and he let it go for 500 engine and trans so my question is i now ive been researching about axles and **** but cant find anything on ecus and wiring harness which ones should i use im droping it in a 93 del sol. or wat yall think i should do sell and look for something els or keep going with swap. thanks in advance for your help
Old Nov 21, 2011 | 12:54 PM
JDM-Punk's Avatar
Default Re: need help with swap
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%2A%2A%2Ah22a-into-civic-eg-ek-information-post-all-h22a-hybrid-info-here%2A%2A%2A-650329/
hope this helps... taken directly from the stickies in the hybrid section
Old Nov 21, 2011 | 05:27 PM
Former User's Avatar
Default Re: need help with h22a jdm swap into 93 Del Sol
Please summarize simple tech question in the thread title - edited.
Old Nov 21, 2011 | 06:06 PM
ls civic ej1's Avatar
dont take my word as i dont know anything about del sols or h swaps. but im fairly sure you should use the del sol wiring harness
Old Nov 21, 2011 | 06:27 PM
crx_si-r's Avatar
you will use your stock engine harness that matches your car, not the motor, and make the needed modifications.
Old Nov 22, 2011 | 09:38 AM
and does it matter the year of the ecu and thanks that helped alittle ill look over it again thanks
loveda07
Jun 8, 2008 09:50 AM
RICE_CR
Mar 24, 2006 06:51 AM
dellyh22a
Nov 14, 2005 05:25 PM
