Which bushings are affecting alignment?
Car: 94 EG coupe at 225k
Suspension: Stock
Tire (for curiosity's sake): Yoko S.Drive 195/45/16
Situation: I have had to get 3 alignments in the past 2.5 years because my car keeps shifting out of alignment. In that time, I've gone through 2 sets of tires (I drive a lot) with a lot of rotations and 1 unmount-wheel flip-remount on each set just to get relatively even tire wear. Since I just ordered a set of Progress CS-II's and will be at my doorstep next week, and since I will be swapping my axles (ripped boots swapping in reman's) I figured I might as well fix this issue as well. I replaced my RTA bushings less than 15k ago assuming it was the main culprit, which did help, but did not completely solve the issue.
Question: What other bushings are major causes of alignment shifting? Where can I get some good prices on oem-style rubber bushings?
If the answer is all of them, can I get some help on specifics? I need to know which ones to order.
Suspension: Stock
My car has been in one minor accident where I rear ended someone. No bumper crack, no frame damage, just cracked paint.
I jacked it up this past weekend to see if there was any visible wear on any of the other bushings, but to be honest I did not know which ones to check. The LCA bushings (front and back) have very minor cracks from what I could see, but didn't know how to check any of the other ones without complete disassembly
I would think wheel bearings and tie rods before i would think bushings. Wheel bearings wheel cause a good alignment to go bad right from the get go. Grab your wheel and try and push and pull it back and forth. If it clicks or wiggles then that's the culprit.
EKwreckRLS
14
Jul 26, 2011 02:45 PM
JasinC19
Apr 30, 2011 06:51 AM
solsi2000
Suspension & Brakes
11
Feb 9, 2009 11:26 PM
94CoupeEJ1
Jun 17, 2005 12:49 PM
The Internet Tough Guy
Oct 25, 2003 07:47 PM
