I need a write up on how to install b16 oil pan please
Old Nov 21, 2011 | 04:43 AM
namewasdallas's Avatar
Default I need a write up on how to install b16 oil pan please
Hey guys, I'm looking for a write up for a b16a oil pan install as mine has messed up threads on the oil pan drainage hole and is leaking a little oil on are new drive way. Also the oil pan gasket looks bad. This motor is old its a b16a I bought from Hmotorsonline about 6 years ago and put on 70kmi I should of replaced it then but I didnt..
So if anyone can explain what I have to Torque the bolts to and which RVT to I use to help seal the pan up would be great. Also does the rvt go on the block/gasket or Pan/gasket????????
Old Nov 21, 2011 | 05:00 AM
dSquirrel's Avatar
Default Re: I need a write up on how to install b16 oil pan please
8.5ft lbs.
just tighten them in a criss-cross pattern, it's not THAT important which one you start with, just don't do one side, then the other or a big circle.
and you don't really NEED RTV on the gasket, but if you do, put it on one side or both sides, it doesn't matter. but you the high-temp petroleum resistant rtv. (i think it's the black one)
It took me 3 seconds on google to find the torque specs. use it next time.
Old Nov 21, 2011 | 09:20 AM
Thanks for the answer and sorry I dont use google dont care to use it when I can ask people and get the answer here on Honda-tech.
I just picked up a Oem b16 oil pan gasket now im looking for this website i found a oem b16 oil pan for $105.00 but i closed out of the page ...
Old Nov 21, 2011 | 09:32 AM
Turpid Porpoise's Avatar
You would rather type an entire post than type "b series oil pan install" in google?
Old Nov 21, 2011 | 10:11 AM
24TEN's Avatar
PHANTOM MENACE
That made me LOL for real
Old Nov 21, 2011 | 10:39 AM
jdmadam's Avatar
This
Old Nov 21, 2011 | 11:58 AM
I guess if you can't figure out how to install an oil pan you can't figure out google either
Old Nov 21, 2011 | 01:35 PM
dSquirrel's Avatar
sig.
Old Nov 21, 2011 | 02:14 PM
JDM-Punk's Avatar
im willing to bet he thinks like so... "why work, when you can have other people work for you"
Old Nov 21, 2011 | 02:26 PM
Jdubbs6101's Avatar
Why am I sitting here breathing like a chump when I can have that machine do it for me.....(in my best homer Simpson voice)
SEATownboi08
Dec 7, 2010 03:09 AM
Si-Samuri
Jan 7, 2009 03:25 PM
nb0
Jun 30, 2008 11:02 PM
Lucky_Smurf
Feb 8, 2005 04:46 PM
deconstruct
Jun 18, 2004 01:00 PM
