Trying to tighten my throttle cable
Hey im trying to tighten up my throttle cable to the recommended 1/2 inch deflection by honda. I was wondering if i need a new throttle cable, cause i tightend up the slack on it (did some experimenting on 4 diff settings) and notice that the RPMs dont go up at all, no difference. And i know im doing it in the right direction cause i tried going the opposite way all the way to the end and the gas pedal was lose as hell. Scared me for a sec. The gas pedal response is good, (i can gently set my foot on the gas with barely any weight and the car will start to move)
The thing is, when i tighten it almost as far as the bolts can go to the left, i still have about 3/4" slack in it when i check for the deflection. What the hell?
Unless im not checking for the deflection properly. How exactly doyou check for 1/2" deflection? Can i do it with the cable already in and tightened?
What arent my RPMs going up?
The deflection should be 3/8 - 1/2 inch (10 - 12 mm). You check it by gently lifting/pushing the throttle cable between the adjustment nuts and throttle body linkage.
Make sure the throttle valve is fully opening and closing when you press and release the accelerator from full-throttle to idle.
So im guessing you check for deflection when its not tightened back up? what do you mean between the nuts and TB linkage? Cause all i see is the TB cable on the very left (the thin wire)
Thats what i thought thanks. So the deflection can be checked as well with the bolts tightened right? I just push on the thin grey wire with my finger and see how much it moves out. Im still getting 3/4 of an inch even though im almost all the way to the left
19992civichatch
Jan 10, 2007 06:27 AM
KTeller8
Aug 2, 2002 02:53 AM
05, adjust, cable, car, civic, crx, deflection, honda, linkage, slack, spefication, throttle, tighten, tightened, tightening
