stock brake lines and wilwood brakes
Old Nov 20, 2011 | 02:09 PM
phaze's Avatar
Default stock brake lines and wilwood brakes
hey guys wanted to know if the stock brake lines from a 00 civic SI can work or fit on a wilwood BBK or would i need to buy the wilwood lines or an adapter to make the stock line work?
Old Nov 20, 2011 | 02:12 PM
germanturtle's Avatar
Default Re: stock brake lines and wilwood brakes
i ran stock lines with brembos without problems. id change the prop valve and bmc
Old Nov 20, 2011 | 04:19 PM
ccbb34's Avatar
I would go for the willwood lines with the setup. I sure you could make the stock lines work, but you will love the pedal response and the feel of the steel braided lines. especially if you are gong with upgraded calipers, why wouldn't you go with upgraded lines?
Old Nov 21, 2011 | 07:18 AM
phaze's Avatar
well the thing is i bought the kit used and they didnt come with brake lines, ive realized that the connection on the caliper for the stock lines dont fit on the wilwood calipers, and was wondering if there is an adaptor to fit into the stock lines and then into the wilwood calipers?
Gamble-Did-it
Suspension & Brakes
May 23, 2018 10:57 AM
redboost10
Suspension & Brakes
Oct 30, 2008 08:55 AM
ITR3189
Jun 13, 2008 01:50 PM
navin
Nov 4, 2003 05:13 PM
Charles B.
Nov 11, 2001 04:04 PM
