How to remove the Bitch pin in less than 5 min.
Old Nov 20, 2011 | 01:25 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default How to remove the Bitch pin in less than 5 min.
You need a c-clamp, a 12mm bolt and a socket. The socket is to allow room for the bitch pin to be pushed into. Put the bolt on the opposite side and tighten the c-clamp until the pin is out. Hours were spent before this came to mind.
Old Nov 20, 2011 | 01:35 PM
grumblemarc's Avatar
The Grumpiest
Default Re: How to remove the Bitch pin in less than 5 min.
Really should have got some pics. Some may not be able to visualize this.
Old Nov 20, 2011 | 01:41 PM
Linked's Avatar
its sounds similar to how you would normally install a lower ball joint, but instead of pressing it in, your pushing it out
Old Nov 20, 2011 | 01:47 PM
Yeah I was to the point I just wanted to be done but basically it would be something like... Hope diagram helps
If you tighten the C- clamp it will push the bolt into the shift linkage removing the B.P.
_ top of C-clamp.
T-bolt
O-shift linkage
U-socket to catch bitch pin
_-bottom of C-clamp
Old Nov 20, 2011 | 02:34 PM
Former User's Avatar
http://www.performanceforum.com/wesv...tch/bitch.html
Old Nov 20, 2011 | 03:10 PM
94_civic_dx's Avatar
I've always use a 10 or 12mm bolts tapped it out takes a few seconds to do
Old Nov 20, 2011 | 03:14 PM
apexi_rsx's Avatar
ive seen a tool made already if u search check here : http://www.performanceforum.com/wesv...tch/bitch.html
Old Nov 20, 2011 | 03:35 PM
I was told to use a 12mm bolt to tap it out before I even started but it didn't budge. I didn't have the room to work. I like the screw bit idea, less to try and keep in place while tightening. Wish I would of seen that link prior, would of saved a few hours
Old Nov 20, 2011 | 03:43 PM
Freshdot's Avatar
took me about 3min to come up with the idea of using a 1/4" rachet extension and a hammer the first time i did this.
Old Nov 20, 2011 | 06:39 PM
imptricer's Avatar
12mm a/c bolt has a tappered end and pushes all the way through on less than a minute everytime
Old Nov 20, 2011 | 06:44 PM
racebum's Avatar
matco is who makes the correct tool for the bitch pin. buy one, this is a nightmare without it
http://www.matcotools.com/catalog/pr...MER-LINK-TOOL/
i never come in the civic forum, just noticed this as a top thread and thought i would share a way to save hours of frustration for $26.70
Last edited by TomCat39; Feb 15, 2015 at 10:24 PM. Reason: fixing url to be the tool and not a page that the tool may or may not be on anymore.
Old Nov 20, 2011 | 07:05 PM
Freshdot's Avatar
Old Nov 20, 2011 | 07:11 PM
civicStyle's Avatar
i made my own tool. works in ten seconds.
Old Nov 20, 2011 | 07:16 PM
98civdx's Avatar
Master Detailer
I use a punch, and a BFH. hasn't failed me yet.
Old Nov 20, 2011 | 07:21 PM
civicStyle's Avatar
only thing that sucks with that, if your working on the gound and dont have the room to swing a hammer. maybe ill post a video of my method. it does involve having a air hammer.
Old Nov 20, 2011 | 07:24 PM
m3tech95's Avatar
good info.....
Old Nov 20, 2011 | 07:37 PM
98civdx's Avatar
Master Detailer
How high are you jacking the car up?
Sure it's a little tight under there, but there is enough room. Well, for me.
Old Nov 20, 2011 | 08:10 PM
v8killaz's Avatar
yeah make a video next time i guarantee i can take it out faster than you with a air hammer
using a cclamp is retarded
Old Nov 20, 2011 | 10:33 PM
Nisif's Avatar
I've always used a honda a/c compressor bolt with no issues. It's roughly 4.5" long with a 12mm bolt head and they're 4 of them that mount the a/c compressor to the a/c compressor engine block bracket. The tappered end fits directly into the "bitch pin". If it's been a while since it's been removed soak it in wd40 then lightly hammer it out.
Old Nov 21, 2011 | 06:37 AM
Humphrizzle's Avatar
this is like the easiest thing in the world.. i dont understand why someone had to make a DIY on it..
Old Nov 21, 2011 | 06:39 AM
crx_si-r's Avatar
i always just used a small torx bit. was out in 3 whacks.
Old Nov 21, 2011 | 07:32 AM
Freshdot's Avatar
primative rocket science if i say so myself.
Old Nov 21, 2011 | 10:56 AM
sde780's Avatar
I always just removed the shifter and kept the bitch pin in...hammering upside down for 1 hour is not fun
Old Nov 21, 2011 | 12:03 PM
hyperblu's Avatar
i understand what he means.
gotta love paint:
Old Nov 21, 2011 | 12:17 PM
4cylfiend's Avatar
I was pulling my engine out a few weeks ago and couldnt find punch to get the pin out. So I started digging around the garage and pulled a spare b-series valve out of a junk head that I had laying around.
Put the top of the valve (small end) up to the pin and gave it 3 taps with a hammer and it was out!
Best tool ive used so far.
