PICKED UP AN 01 ITR LAST NIGHT...JUST GOT HOME 3 HOURS AGO.
Old Nov 20, 2011 | 11:21 AM
tvrsir's Avatar
Default PICKED UP AN 01 ITR LAST NIGHT...JUST GOT HOME 3 HOURS AGO. SOO PISSED.
THIS CAN'T BE NORMAL.
I GOT THIS **** ALL OVER THE BUMPER AND SOME ON THE WING...THIS CAN'T BE NORMAL
OIL CONSUMPTION.....
WHAT DO YOU THINK?
Old Nov 20, 2011 | 11:27 AM
Keilani's Avatar
Default Re: PICKED UP AN 01 ITR LAST NIGHT...JUST GOT HOME 3 HOURS AGO.
POST MORE PICTURES!
Old Nov 20, 2011 | 11:30 AM
00TypeR's Avatar
Mods, boosted, any tuning software?
Mine looked like that when I was s/c'd. Pretty sure you see that when you are running rich.
Old Nov 20, 2011 | 11:34 AM
FULLYBUILT2.0's Avatar
Yeah that's differently oil!!! Did you check how much oil is burning? How many miles? Try doing a compression test first and follow with a leakdown test asap.
itr#1334's Avatar
Doesn't necessarily mean you burn oil. Could be just unburnt fuel from running rich like Derek said Happens when you burn oil as well though. Do you blow smoke in vtec? Compression test won't tell you much. Do a full leak down test.
Old Nov 20, 2011 | 12:26 PM
Keilani's Avatar
By blowing smoke in vtec ITR1334 what would that indicate, that hes burning oil?
Old Nov 20, 2011 | 12:41 PM
tvrsir's Avatar
well when i picked up the car. i check the fluid and it was at in between the bottom and top. i figured because it was just running that all the fluid hasn't drained to the pan yet. it was slightly dark.
the car exterior and interior is very clean. so it wasn't a total lost but i am pissed i paid 15k for a car i have to put in new rings.
i drove from new york to chicago 820 miles and it burnt 1.5 quartz of mobil synthetic at maybe 2 vtec pulls and constant 70mph home.
i noticed when i went in vtec i see a cloud of black smoke.
you can definitely smell combustion gas inside the oil if you open the oil filler cap.
Old Nov 20, 2011 | 12:47 PM
tvrsir's Avatar
HERE IS THE LINK TO THE CARS LISTING.
http://hondamarketplace.com/showthread.php?t=2976903
IM UPSET THAT I WASN'T INFORMED OF THIS WHEN I PICKED UP THE CAR. I COULD HAVE CLEARLY DESTROY THIS ENGINE ON THE WAY HOME HAD I NOT CHECK THE FLUID AND TOP OFF EVERY FILL UP.
Old Nov 20, 2011 | 12:57 PM
itr#1334's Avatar
Pretty much all itr's will blow a little smoke in vtec. Depends on how much smoke and what color.
OP, sorry to hear. Sad to see a dishonest seller. Honestly though thats not a ton of oil burning. Looks like a very clean caR.
Old Nov 20, 2011 | 01:04 PM
tvrsir's Avatar
TRUST ME IT ALL OVER THE BACK OF MY CAR. EVEN ON THE WING. THAT JUST RIDICULOUS. I DON'T THINK THAT IS NORMAL OF ANY HONDA ENGINE.
I HAD A JDM ITR MOTOR IN MY GSR 4 YEARS AGO AND IT NEVER CONSUMED ANY OIL OR LEFT ANY TYPE OF RESIDUE ON MY BUMPER.......
I LOVE THE CAR, BUT THIS IS A BUMMER BECAUSE I GAVE HIM GOOD MONEY FOR IT. I WOULDN'T PAY NO MORE THEN 13K IF I KNEW.
OH WELL MY LOST AND I LEARN NOT TO BUY A DAMN CAR FROM FAR FAR AWAY....
Old Nov 20, 2011 | 01:07 PM
slowturbocx's Avatar
I would do a leakdown test and then go from there.
Old Nov 20, 2011 | 02:47 PM
motegicivic's Avatar
I had a rich running condition, but would take a bit for the back bumper to load up like that.
Yours almost looks wet, I am thinking bad rings, maybe valve seals.
Too bad you didn't have it checked out before buying.
Old Nov 20, 2011 | 03:41 PM
oldintegrao's Avatar
Sorry about the luck. While that does seem excessive I would try to calm down and do a leakdown test and a good tune up first. If it was running rich it could easily do that. Does not always mean it is blown rings. I run Mobil one but it is known for burning much faster than other oils. I would try something else, make sure the ECU is all oem/stock, and make sure no injector issue before I write it off. Good Luck
OH AND TURN OFF CAPS LOCK!
Old Nov 20, 2011 | 04:17 PM
postman's Avatar
check to see if it smokes on a cold soak.make sure it has the factory pcm, fuel injectors, fuel pump. a leak down and compression test wont tell you if you have an oil consumption issue typically. especially if the car seems to run fine. if it is burning oil. change the fluid to a thicker weight and dont use a synthetic. might buy you some time.
Old Nov 20, 2011 | 04:30 PM
tvrsir's Avatar
Gonna do all that tomorrow and keep u guys updated.
I had no choice, I bought a one way ticket to come get the car. Trusting that the car has no physical or mechanical conditions.
It was my ride home.
Old Nov 20, 2011 | 04:37 PM
tvrsir's Avatar
Dont regret buying the car. I waiting 14 years. Just wished people would be more honest.
I'm not so sure that he even know it burned that much oil. He drove it for only 3000 miles. And it was more a garage queen.
Maybe whoever sold it to him wasn't truthful. But hey I got an itr. Just wish I didn't have to open the engine
Old Nov 20, 2011 | 04:48 PM
Ebay right? Doesn't ebay have buyer protection? Negative feedback if not resolved.
As for him having it 3k miles, I am sure that showed up.
Do a compression test at least, if that seems ok.
Do a simple tune up, cap, rotor, wires, plugs, even the O2 sensor, switch to reg oil.
Then see how it is.
Another thing, if the car is not driven much can be just as bad as beating on it.
Old Nov 20, 2011 | 04:55 PM
cmdr430's Avatar
First off, I would quit running Mobil 1... It is **** oil for these cars... Try running regular castrol through it a couple thousand miles and see if that helps...
My 98 ate up Mobil 1, but my 00 and current 97 were/are running castrol gtx and don't consume any......
Old Nov 20, 2011 | 05:53 PM
crx(gator)'s Avatar
seems like it needs new rings to me, seeing that you burnt 1.5 quarts in only 800 miles. i cant believe you looked at an ITR for $15,500 with 78k miles though.
good luck with it either way.
Old Nov 20, 2011 | 05:57 PM
tvrsir's Avatar
not ebay.
cash deal..
will try new oil. all i did was topped it off with mobil one at the rest stops.
tune supposely been done.
i will go over the car with a microscope tomorrow. gonna check EVERYTHING!!!!!!
Old Nov 20, 2011 | 05:59 PM
tvrsir's Avatar
besides the oil burning, this cars condition is well worth 15k if it didnt burn oil
Old Nov 20, 2011 | 06:12 PM
DA_RS's Avatar
good luck playa
Old Nov 20, 2011 | 06:20 PM
Originally Posted by tvrsir
not ebay.
cash deal..
Report back, worst case you might have to invest in the engine work, but seems nice overall.
Old Nov 20, 2011 | 06:34 PM
PaulMc's Avatar
Painfully Stupid
WHAT DO YOU THINK?
Story of my life. Mine needs piston rings.
Old Nov 20, 2011 | 07:30 PM
RGoose18's Avatar
My aftermarket cat has caused alot of black gunk on my bumper, you have a bit more, but is your cat stock?
