2001 Accord Coupe door lock problem and sun roof problem
Old Nov 19, 2011 | 09:01 AM
nicholec's Avatar
Default 2001 Accord Coupe door lock problem and sun roof problem
First problem: I have a 2001 accord coupe and the passenger door lock switch doesn't work. I can lock and unlock both doors automatically by using the driver side door lock switch and by doing it manually but when I hit the passenger side door switch nothing happens, no noise or sound and neither door locks or unlocks? It seems like the locks work they just doesn't respond to the passenger unlock/lock switch.
What could this be and how can I fix it?
Second problem: My moon roof will only open 75% of the way. It has no problem opening and closing but its not opening all the way. I have tried to gently push it back to see if it will go back further and nothing happens.
What to do?
Thanks so much!
Nichole C.
Old Nov 19, 2011 | 09:29 AM
uhhkilleez's Avatar
Default Re: 2001 Accord Coupe door lock problem and sun roof problem
Not sure why either of those things are happening but in my trunk there's a little tool kit in a little compartment and it has a sunroof wrench, have you tried using that? Maybe see if it will even open all the way with the wrench, maybe something is stuck in there and blocking it from opening all the way. I never had problems with it not opening or closing all the way but sometimes it opens and closes real slow as if the motor is going bad.
My dad's bmw had the same problem with the locks on the back doors but they wouldn't even open manually. Sorry I couldn't help much
kevpple
Honda CR-V & Element
Jul 7, 2011 07:34 PM
darcus.t
Jul 8, 2010 09:03 AM
kmy
Dec 22, 2009 05:54 AM
Dropped90Integra
Jul 21, 2005 07:50 PM
Bishop Don Shizzle
Jan 26, 2005 12:10 AM
