94-97 shift cable bushings?
Old Nov 18, 2011 | 06:48 AM
twkdCD595's Avatar
Default 94-97 shift cable bushings?
So I am looking to replace my shift cable bushings with something more precise.
Problem is I am finding very little information about if the bushings at the trans end and are they the same size as say a 90-93 accord or a h series prelude cable bushings.
Anyone have any insight? Hybrid Racing makes some nice ones for H series prelude cables and TWM makes some for 90-93 accords and 97-01 preludes. However neither will say if the 94-97 cables can use this same size/ diameter bushing.
Old Nov 20, 2011 | 07:13 AM
twkdCD595's Avatar
Default Re: 94-97 shift cable bushings?
Nothing huh, kinda what I am running into most places. No one is sure if the diameter of the bushings are the same on the trans end of the cables.
Kinda risky but guess I could press out the bushing and mic mine then hope hybrid or twm would tell me if the ones they have would match that.
Old Nov 20, 2011 | 07:39 AM
lieu95accord's Avatar
these are the only ones i found, i'm gonna order them in the spring, they have them for 94-97 accords
http://www.corsportusa.com/store/cat...oducts_id=2218
Old Nov 20, 2011 | 06:36 PM
twkdCD595's Avatar
Thanks for the link, I did not see those. Not quite as nice as the Hybrid or TWM ones but should get the job done.
Old Nov 20, 2011 | 07:58 PM
no problem if u decide to pick them up let me know how u like them. are u still running the boosted f22b1?
Old Nov 20, 2011 | 08:58 PM
twkdCD595's Avatar
My stock bushings are in decent shape but I am trying to elimate a bit of squish in my shifter that is annoying me, hopefully these will help. I know some people say these aluminum bushings will start to gall and wear, hoping that is not the case. The TWM ones are said to have a self lubricating coating on them and the Hybrid Racing has a spherical bearing in one bushing but not the other. A little grease in the center hole to keep them lubricated should keep that to a minimum though since I am unsure those others will work.
Yea still on the F22b1... pushing a bit of boost to it. Come spring maybe a bit more with a retune at T1 for some new fuel.
Tinker219
Dec 14, 2024 05:18 AM
dansaleen_04
Oct 6, 2010 02:36 PM
Zeusone
Honda Civic (2006 - 2015)
Jul 19, 2009 03:12 PM
1stgenboost
Honda Civic (2001 - 2005)
Mar 3, 2009 03:10 PM
